02 rear caliper on 05 ???
9 replies to this topic
  • ncmountainman
Posted August 08, 2006 - 12:33 PM
will a 02 yz 426 rear caliper fit on a 05 yz 450,the reason being i think i need the 27 mm caliper of the 02 compared to the 25.4mm for more braking power with my rear hand brake :thumbsup: the m/c unit from rekluse has a 9.5mm piston,the only concern is will a larger caliper move enough with that size m/c? magura makes a 10 and a 13mm m/c,but i've been told that the smaller piston in the m/c will require less force;so will a larger piston in the caliper do what i'm looking for or make the situation worse?...any hydraulic junkies out there?
  • ncmountainman
Posted August 09, 2006 - 02:47 PM
so does anyone know if the 426 rear caliper will interchange with the 450's???? i searched it and came up with they might swap but the 426 pads are bigger(by about 20%) and the 450 rotor is bigger by 5mm. sounds like it might work :thumbsup: gray,anyone??
  • ncmountainman
Posted August 14, 2006 - 06:37 AM
HELLO>>>>is this thing on? somebody must know if it'll fit :thumbsup: has anyone put a 03-05 caliper on a 426? i guess if it works that way it would work the other. i'd really hate to buy one just to find out it won't work :ride:
  • Ga426owner
Posted August 14, 2006 - 07:10 AM
If I knew NC I would tell you.............. :thumbsup:
  • Matt96xr6
Posted August 14, 2006 - 07:20 AM
swingarm will be the same 02-05, so if you get the caliper and the caliper bracket that the axle goes through it may work.
  • ncmountainman
Posted August 14, 2006 - 07:57 AM
cool,sounds like i just need to lay out the complete assembly for each and see what fits :thumbsup: gotta love a frankenbike! the feller that bought my old WR has to consult with me everytime he works on it, there were so many things changed around :ride: now i just need a 02 donor bike :applause:
  • essex426
Posted August 14, 2006 - 09:25 AM
I just fitted 450 wheels to my 426,and the disc was bigger,but no problems fitted right up.
So think you will be ok.
Now back to running a 9.5 magura, can pull lever to bars, but feels more like front brake lever than 10.5,easier on the hand.
  • essex426
Posted August 14, 2006 - 09:44 AM
Just re-read your post, think you might have more braking power with what you are already running.
Going with bigger caliper piston,or smaller master cylinder piston,reduces lever pressure i think.
10.5mm will lock mine easy but gets tiring,that's why i went back to 9.5mm.
What is the problem to heavy a lever, or not enough braking power.
  • ncmountainman
Posted August 14, 2006 - 12:18 PM
not enough braking power after it heats up
  • essex426
Posted August 14, 2006 - 01:14 PM
Did not get brake fade with the 10.5 mm, just hard work after a while.
Might be worse with the 450's smaller caliper piston.Or you could end up with popeye's forearm.
Motocross
  • Hot  491 replies
  • On Yesterday, 06:20 PM
  • Hot  28 replies
  • Hot  113 replies
  • 0 replies
