06YZ450F Bogging
14 replies to this topic
  • gerald28
Posted August 08, 2006 - 05:13 AM
Hey everyone,
I bought a 06YZ450F this past May and have loved it. 2 weeks after I purchaed it, once I broke it in, I had the shop rejet it (it was backfiring a lot). Since then, it ran great.
Two weeks ago, it started bogging at the first throttle crack. If I roll it on slowly it is ok, but if I turn it with any speed it bogs and/or dies. I thought I might have over oiled my air filter (but I have changed it twice since). Prior to 2 weeks ago, the same crack would not bog it. I have not changed settings or parts since then.
Any suggestions on where to look? I assume it is a jetting issue. What might cause it to change all of a sudden?
1) The bike is stock, with only a Boyseen water pump put on in June.
2) I ride MX and Enduro in Central/South Texas
3) It is hot and humid, but it is always that way down here:)
Thanks!
Gerald
  • rcmxracing
Posted August 08, 2006 - 05:20 AM
Your fuel mixture screw didn't fall out did it?
  • gerald28
Posted August 08, 2006 - 05:23 AM
I couldn't imagine, but I am certainly going to check when I get home.
Thanks,
G
  • Ranger18
Posted August 08, 2006 - 06:09 AM
I was thinking the same thing.. If it isn't out, then it is probably close to falling out. You should replace it with a zip tie screw if you have the stock one in. Otherwise turn the screw in, then back it out about 2 turns and adjust from there.
  • jamiehughes
Posted August 08, 2006 - 07:45 PM
maybe, dirty air filter??? just a shot in the dark..
  • jwcrf05
Posted August 08, 2006 - 08:54 PM
the temp and humidity levels haven't changed have they? my bike ran great all spring then about halfway through the summer the thing bogs like crazy. a smaller pilot jet and one smaller on the main was the cure, we have been in a heat wave lately so temps are hotter and humidities are higher than normal, you might be able to dial it out with the pilot screw though. try a 165 main and a 45 pilot if thats not what you are already running.
  • Joe_Jet
Posted August 09, 2006 - 05:16 PM
Sounds like they jetted the pilot too rich.
  • Troutman
Posted August 09, 2006 - 05:28 PM
I am thinking the same thing. If your bike doesn't pop at all, even a little bit, on decel it might be to rich. I would try turning your fuel screw in a 1/4 turn at a time and see if that helps. If it doesn't and if they put in a 48 or bigger pilot you might try a 45. Mine did the same thing in the woods and I adjusted the fuel screw and that cleared it up but it now pops very slightly on decel. If you are still running a stock fuel screw you also might want to get a Zipty or Stealth it will help with the fine tunning.
  • Budlite
Posted August 09, 2006 - 06:53 PM
If you've lost the fuel screw get the Zip-Ty with the knob on it, they make two versions. You'll also need the spring, washer and o-ring. Suzuki sells them individually. Honda, Yamaha, and Kaw sell them as a set. Big difference in price because they come with the screw itself. You might consider extras as they are hard to get in a hurry. Once installed, safety wire it so that if it comes loose again, it won't fall completely out.
  • redrider91
Posted August 09, 2006 - 07:09 PM
Our fuel screw fell out and we had this problem, so we bought an aftermarket one and turned it in all the way then 1 1/4 out and it runs great. I just have no clue how the stock one could fall out but w/e.
  • matt116
Posted August 09, 2006 - 07:13 PM
A little o-ring around the fuel screw will keep in place. see pic
http://i69.photobuck...uelscrew007.jpg
  • gerald28
Posted August 09, 2006 - 09:13 PM
Ok, I checked it. It has not fallen out. Unfortunately, I was not smart enough to ask the dealer where they set it when it was rejetted...so I don't know if it has come loose at all.
I figure I will reset it to 1.5 to 2 turns out and go from there.
Thanks for the help everyone!
  • gerald28
Posted August 09, 2006 - 09:14 PM
Yea, I thought it might be that or that I over oiled the filter. So I have changed it twice over the past 10 days just to be sure.
  • gerald28
Posted August 09, 2006 - 09:16 PM
How many degrees will make a difference? I live in central texas, so it is HOT. But I had it jetted in late may or early june. So it is only a few degrees hotter now than early summer.
  • gerald28
Posted August 09, 2006 - 09:18 PM
Yea, it does not pop at all. Boy when it was new, before the rejet...it poped like a popcorn maker. But even now that it is bogging, no pops.
i will try turning in the screw to see how that helps.
Thanks
Gerald
  • Hot  113 replies
  • Hot  36 replies
  • On January 15, 2017
