Baja Design tailight question
3 replies to this topic
  • MindBlower
Posted August 05, 2006 - 07:51 AM
My brake lights not coming on. Running light is lit. Can the bulb fail this way?
I've got the troubleshooting guide from BD to use if not.
  • hypersthenos
Posted August 05, 2006 - 10:08 AM
Not uncommon for the bulb housing to break off inside the assembly. Remove the lense & check the wires where they are soldered inside the bulb socket. Also, the male/female connectors under the seat are not the best. Pull them apart, make sure they're clean & reassemble. If they are a bit loose, lightly crimp the female ends with pliers for a tighter fit.
  • motochris
Posted August 05, 2006 - 10:33 AM
Very common. It's a 2 filiment bulb. The brake one is probably bad. For some reason I used to go through a bulb about every 2 months or so.
  • MindBlower
Posted August 05, 2006 - 11:22 AM
thank you
Washington
  • Hot  32 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • 4 replies
