Dual Sport WR
10 replies to this topic
  • BigIan
Posted August 04, 2006 - 06:20 PM
I want to put my '04 WR 450 on the road, but I don't like the look of the DS kit headlamp assemblies, and after reading many threads here, I sure don't feel like shelling out for a kit I don't need anyway. It also appears that the WR comes stock with two-filament bulbs for both the tail/brake light and for Hi/Low beam up front. This leads me to believe if I get the ProCycle #1 wiring harness and switch assembly (http://www.procycle.us/main/dskit.htm) I would simply need to buy the horn, mirror and signal lights of my choice. Am I right?
Also, I am looking for some suggestions for rear flush-mount signal lights, as there is no convenient mounting spot for stem-style lights at the back.
All suggestions are welcome. :thumbsup:
  • RichBaker
Posted August 04, 2006 - 07:48 PM
You are correct...look in a lockhart phillips catalog for signals. It'd be cheaper to just buy the switch...
  • B-Rock
Posted August 05, 2006 - 12:44 PM
I would suggest LED signal lights such as these.
https://www.bajadesi...ItemCode=603023
Much harder to break when on the trail then regular filament bulbs.
  • johnnyjeep
Posted August 05, 2006 - 03:42 PM
The ones I got from BD looked like those but werent packaged, so I will assume they were the same ones. Those lights suck. They cant be seen during the day. I replaced mine with some I found at the closest M/C shop (a Suzuki/Honda/Kaw). They were cheaper and can be seen. As for your harness, look at this
http://www.farplaces.com/dual.htm
and build your own.
John in Vegas
  • gdm
Posted August 05, 2006 - 05:50 PM
Forget Baja Designs, check out http://trickdualsport.com. You can use your stock headlight and taillight, quality stuff and good support.
  • MountainMax
Posted August 06, 2006 - 06:02 AM
from what I see trick needs to use their own headlight with integrated signal lights, am i missing something? this is why i didn't go with them when i DS'd my bike.
  • BigIan
Posted August 07, 2006 - 04:01 PM
I am thinking I might just order a wiring harness, bar switch and ignition key set off of an xt225 and just install them, thereby keeping my bike "All Yamaha, All the time!"
  • MountainMax
Posted August 07, 2006 - 04:55 PM
There was a guy on here somewhere that was going to give us Yamaha Part numbers for the Kits they install at the dealers in Australia on the WR's down under to make them street legal, he even posted pics, it looked awesome. But he never did get us any part numbers for the kits...... :thumbsup:
  • gdm
Posted August 11, 2006 - 08:39 PM
You can use your stock headlight, that is what I did. Give them a call and talk to Dale.
  • uncleroby
Posted August 12, 2006 - 04:13 AM
I would like to buy a 2006 WR450F and use it like my XR: as commuter, dual sport and trail bike.
Is it reliable and durable enough for such use?
I travel 7000 miles a year, do you think I will need to open the engine every year?
Thanks,
Uncleroby
  • byggd
Posted August 12, 2006 - 04:44 AM
You will need a brake light switch as well.
