KLR 650 Fork oil
Posted 04 August 2006 - 11:09 AM
Posted 04 August 2006 - 09:11 PM
Jesse
Posted 05 August 2006 - 03:01 AM
I use 10w fork oil set at 170 mm in my KLR650 forks. I have Progressive Suspension fork springs in the bike and the front end is about as good as it can get. I'm happy as it gives me better braking, good feedback and handles both on and off road quite well.
Posted 14 July 2009 - 05:15 PM
What year KLR do you have. Will the 170 mm work in a 2008?
Posted 14 July 2009 - 06:01 PM
jjewell said:
I changed the entire setup. Stiffer Cogent Dynamic springs combined with Intiminators with 5w fork oil. Will NOT go back to stock. The improvements are wonderful no matter if it's rock gardens at 10 mph, sudden wash-outs at 40 mph, or carving an undulating curve at 75.
I'm not sure changing the weight is going to do much good. You could try changing the volume in the fork tube...or, adding some air pressure to the forks (the "book" says not to, but, the fork tubes themselves have instructions on how much air can be added).
Posted 08 August 2009 - 02:01 AM
I have klr 650 c (1995). Is my fork identical to a klr650A?
And should I use any 10w20 (like semisintetic) oil or there is some special oil for forks? How much mililitars should i put in? tnx
Posted 07 March 2012 - 05:07 PM
Posted 07 March 2012 - 05:24 PM
5w because it''l pass through the stock dampening rod holes pretty much with little effect letting the emulator do the work. If I enlarged the holes I could use heavier oil.
Posted 08 March 2012 - 11:43 AM
older bikes had oil at either 170 or 190 depending (slight change in about 96). What works the best on Gen one bikes is oil at 165-175. I stick with 10 wt (ATF). 5-15 psi air to trim.
I've done dozens of forks at tech days, NONE had even the minimum unless the owner did the work. I've done many new bikes that were 50-75cc low per leg, one was 200cc low just to get to 190. Proper oil makes a huge difference. Add a fork brace & it's pretty good.
If you want to spend more money, get the Ricor valves... they are fantastic. I mix ATF and Marvel Mystery Oil 50/50 to get 5wt they require. Stock springs are fine.
Posted 08 March 2012 - 08:43 PM
I have an '06 bought a few months ago and I don't know if anythings been done. PO didn't know jack, but he only had it a few hunnert miles and it must have scared him. Runs good.
Fork oil leaked out of the drain screw a bit ago. Looked like nice clean ATF. Tightened it, stopped leak. Now I need to drain/fill. Better springs and valves are in the plan if I keep her. I'm 200# dry. What say you on fill level and any oil recommendations for the '06?
Many thanks.
Posted 08 March 2012 - 09:00 PM
I'm simple with the klr, I just max the rear spring out then tune the front air to balance the suspension f to r.
Posted 09 March 2012 - 01:11 PM
On the 06..... collapse forks, remove springs, fill to 165-170mm from the top. Top with 10psi air. Consider a fork brace, but don't waste money on different springs, go straight to the Ricors.
obviously, the forks need a good cleaning inside too
Edited by Beezerboy, 09 March 2012 - 01:12 PM.
Posted 10 March 2012 - 09:22 AM
I'm not sure about not doing springs. I'm 200 lbs and plan to load this bike up with some armor, tools, gear for multi-day adventures into the Idaho deserts and mountains, and possibly a passeger from time to time. The KLX250 was set up stock for a 150 lb rider. I put proper springs in first and the difference was huge. Then installed gold valves and it was nothing short of amazing compared to the stock setup. I've heard great reports for both the Ricor and Race Tech valve setups and am not yet convinced that one is better than the other. Lots of opinions out there. Like I've heard from a number of riders to avoid the fork brace if I'll be riding off road, rough trails, which I will be. What I want from this bike is a good, solid trail machine that can cruise 75 on the highway when needed. Not as trail worthy and a lot more pavement worthy than the KLX.
Edited by IDRIDR, 10 March 2012 - 09:24 AM.
Posted 10 March 2012 - 10:51 AM
I've heard the prejduce about fork brace off road.... I don't understand why anyone would make such statements on the KLR 650
Posted 10 March 2012 - 12:20 PM
About the fork brace, I don't know why they say it. I'd like to be able to try both with and without.
Posted 10 March 2012 - 06:20 PM
Posted 11 March 2012 - 12:31 AM
Edited by Beezerboy, 11 March 2012 - 12:32 AM.
