why did my rear sag get stiffer 06 450
4 replies to this topic
  • krausemouse
Posted August 04, 2006 - 06:26 AM
Weird. Set sag after break-in at 98mm. Last night we set again...same people/method and it was 88mm. Does the titanium spring actually get stiffer over time? :thumbsup:
  • jgerdi
Posted August 04, 2006 - 06:36 AM
Ditto... I set mine after break-in. I've been having trouble entering corners and was going to take off my works braces thinking the extra weight messed me up. I checked my sag and it was almost at 1/2 of what it should.
  • huffster
Posted August 04, 2006 - 08:12 AM
No the spring does not get stiffer...What is your static sag ? Does the shock seem to be operating correctly or does it have excessive rebound, feel bouncy ??
  • jgerdi
Posted August 05, 2006 - 07:33 AM
Sag was spot on . I'm going to put a paint dot on the collar and threads to see if it is moving and some how making it tighter.
  • moochie
Posted August 05, 2006 - 09:25 AM
If you dont have a big time bindup going on with the rear suspension...the only thing I could think of that would cause something like this if you put on a new chain and/or sprocket and you ended up having to slide your axle quite a bit further forward to account for chain slack.
Spring would not become stiffer with time and the shock collar could not tighten up on it's own either. If you didnt mess with the rear axle and your suspension isnt bound up in the linkage somewhere, it would seem that one of your buddies messed up with the measuring tape.
  • Hot  113 replies
  • 0 replies
