jetting
10 replies to this topic
  • dirtking
Posted August 02, 2006 - 08:19 PM
My elevation is 2500 ft. and temps are around 80-100 degrees. should i still up the pilot jet to a 45 or stick with the stock 42. i have a 2006 YZ450F.
  • FlashGordon
Posted August 02, 2006 - 08:30 PM
I run a 48 in my Yz400. Stops the decel popping, and easier to start. One of the best mods I ever did was to get the JD Jetting kit. I read all the kudos from others, but could not see spending $50 for 2 needles and a few jets. Finally did it. I tell you, the needle for sea level to 5000 ft is worth every penny. I cannot believe how much smoother it accelerates through the entire range.
  • ovrrdrive
Posted August 03, 2006 - 01:06 AM
My first question in a jetting thread is always "How does it run?"
There is no fix-all recommendation for jetting. Every bike is a little different and the conditions, climate, and elevation that you ride in all factor into the jetting.
Does it hesitate, pop, backfire, or bog?
  • yami racer
Posted August 03, 2006 - 05:22 AM
80-100 degrees at sea level:
45 Pilot
165 Main
Runs like an absolute bear....I do agree with ovrrdrive though you have to go by how it runs and start from there. You may be able to just adjust the fuel screw to start with.
Posted August 03, 2006 - 08:52 AM
I would. We've run ours with a 45 at altitudes ranging from 2000-3500 feet so far, and it works fine
  • Baron Von Beard
Posted August 03, 2006 - 10:41 AM
45 Pilot, 165 main, needle on the 4th spot.
  • WFOracer
Posted August 03, 2006 - 10:55 AM
Still.....have you figured out how to stop making popcorn on decel?!?
I have that other needle on order....(the Dubach recommendation from the other thread)
  • Baron Von Beard
Posted August 03, 2006 - 11:07 AM
Mine doesn't pop but I'm running a 48 pilot, 168 main and stock needle on the 4th clip. I tried my Honda needle and it was no good, far too rich.
  • WFOracer
Posted August 03, 2006 - 11:21 AM
I am little confused on the low end/idle. I am running a 45 pilot and sometimes my idle hangs up and pops like mad on decel (lean). When I was running a 48 I was getting little black puff everynow and then but no poppiing on decel(rich). My choke doesn't seem to do much to my idle speed. 4th clip, 2 turns out, 165 main.
  • Baron Von Beard
Posted August 03, 2006 - 11:26 AM
Go with the 48 and adjust the fuel screw in until you aren't puffing any more. :thumbsup:
  • foreverblue
Posted August 03, 2006 - 01:50 PM
I have a 45 pilot and 168 main, Tusk fuel screw out 1-3/4 turns. Check that the idle screw is not out to far, when I was setting up my jetting the idle screw was out to far and it caused the idle to hang occasionally. I would also check to see if the fuel screw is still there when it falls out you're bike will decel pop like crazy.
  • Hot  47 replies
  • Hot  113 replies
