Magnetic oil drain bolts.
23 replies to this topic
  • Turismo
Posted July 31, 2006 - 05:26 AM
I got an '05 WR450, and was thinking about a magnetic oil drain bolt.
From the posts I read when searching, seems people get little or no metal stuck to the magnet when they change the oil. Is this because the oil passes through the filter before it goes past the magnet?
Would it be better to get one for the sump or for the frame? Or both?
Maybe an oil flow diagram might help, if anyone can point me in the right direction.
  • msgbean
Posted July 31, 2006 - 07:02 AM
Turismo the filter will catch the fine stuff but if you have bigger pieces that get loose hopefully they will fall to the bottom and get picked up by the magnet. Otherwise they could get tossed around enough to find their way back in to the gears or plug up an oil passage. The last time I changed my oil I found three pieces of metal about an eight of an inch long stuck to the magnet. Every thing appears to be working fine but my next task is to try and find out where they came from before I have a failure. Bottom line is thanks to the magnet these pieces are not floatiing around causing more problems.
  • Turismo
Posted July 31, 2006 - 04:46 PM
Thanks msgbean, do you have one for the sump or frame?
  • kirkw
Posted August 02, 2006 - 08:23 AM
Turismo,
I have only one in the botom of the motor. I occassionally get a sliver or two, but mostly its just a fine sludge of metal. Even without big pieces, the small cost of the mag. plug seems like a really cheap way to extend the lift of the internals without that extra metal grinding around in there. Worth every penny IMHO.
  • 96xr200driven
Posted August 02, 2006 - 08:28 AM
Turismo,
yeah, it's not spendy and it's better to have all those little pieces of metal out than in. I would get one if I were you.
  • StreetbikePimp
Posted August 02, 2006 - 09:10 AM
I'm a fan of magnetic plugs. The only thing I've ever seen on mine is really fine metal powder, but I feel better not having that powder sand away at the gears.
  • Turismo
Posted August 02, 2006 - 02:54 PM
Thanks guys!
  • RichBaker
Posted August 02, 2006 - 09:40 PM
I have one in my 03, when the starter idler gear broke a tooth it was stuck to the magnet...not rolling around in the cases looking for someplace to wedge itself in between...
  • msgbean
Posted August 03, 2006 - 02:19 PM
I just have one in the bottom. One time I had a lock washer come off the primary gear. It did get chewed up but when I took the engine apart all the chunks were huddled around the magnet.
  • boer
Posted December 09, 2006 - 04:53 AM
Sorry for bringing up a old thread:bonk: I thought this was worth it and wanted to share my happiness:ride:
I did my first oil change since installing the magnetic drain bolt and would recommend to everyone who doesn't have one to put it on their wishlists.:worthy:
These bolts are amazing. I never imagined so much magnetic particles/dust would be there.:D
  • MountainMax
Posted December 09, 2006 - 10:11 AM
I too love the added help from a magnetic bolt, You can pick up some fine metal before it gets pumpup up the the filter
  • msgbean
Posted December 09, 2006 - 12:59 PM
The last time I changed my oil I found three pieces of metal about an eight of an inch long stuck to the magnet. Every thing appears to be working fine but my next task is to try and find out where they came from before I have a failure. .
Back in July I wrote the above quote. In September I finally found out what those pieces were when it starting slipping out of third gear. They were pieces of the lugs on third gear that mesh with and engage fifth gear. So I had to replace 3rd gear, 5th gear, and the shifting fork.
  • specialk6r
Posted December 09, 2006 - 03:01 PM
Just came across a combo set with a magnetic drain and frame plug. They claim it's stronger than a regular ceramic magnet. Anyone try these? Seems like a good price. If it fits the 250 it'll fit the 450 too won't it?
http://cgi.ebay.com/...s_promot_widget
  • MN_Paul
Posted December 09, 2006 - 03:48 PM
The one from the TT store for the engine lists this:
Fits:
01-06 Yamaha YZ/WR250F
03-06 Yamaha YZ/WR450F
  • Wasabi
Posted December 09, 2006 - 04:42 PM
These bolts are amazing. I never imagined so much magnetic particles/dust would be there.:cry:
:D :prof: :bonk:
Yep, definately one for the list!
  • Sycamore
Posted October 01, 2007 - 01:02 PM
Are they out for the 07's yet?
  • msgbean
Posted October 01, 2007 - 03:57 PM
This is where I got mine. Its for an 06 YZ but it is the same.
http://www.magneticd...Plugs/MP07.html
  • Sycamore
Posted October 02, 2007 - 07:39 AM
Thanks, I just bought it!
  • climaxx dirtbikes
Posted June 14, 2010 - 01:03 PM
So it definitely fits our 07 450?
  • Mutu
Posted June 15, 2010 - 12:22 AM
yes it is the same.
