xr 650l poping on decel
3 replies to this topic
  • mstrav
Posted July 28, 2006 - 10:16 PM
i just purchased an 03' xr 650l. it has w.b. slip on, all the smog stuff removed and the guy i bought it from said the local honda shop re-jetted it for him (not sure if dyno jet or just new jets). on other bikes i have had i would just adjust the idle mixture screw out if the bikes pop on decel. is this the same for this type of carb? thanks for any help.
p.s. other then this the bike runs fine and really rips. pulls the front up no prob. with just throttle no clutching!!!!!! :thumbsup:
  • OUTERLIMITS
Posted July 28, 2006 - 11:28 PM
I've had a lot of luck correcting that problem swapping up to a larger pilot jet. I imagine yours is a CV type carb. You will need to open her up anyway to find out what you have, but once you have your jet specs, I'm sure with a search you can find what has worked well for your bike with an aftermarket pipe so you wont' have to do much experimenting. Good luck.
  • TrailRiderXRL
Posted July 29, 2006 - 02:29 AM
Search for Dave's mods. That will fix your problem. It did for me!
  • nxridge
Posted July 29, 2006 - 04:53 AM
I removed all the smog junk and was surprised that it didnt realy
stop any of the popping on decel.
The bike still needs to be jetted , but obviously the smog pump
doesn't have much to do with the popping .
if the popping slowed down 10% after pump removal i would be surprised.
  • 3 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 8 replies
  • Hot  35 replies
