When Does break-IN end??
4 replies to this topic
  • Lit_Dueler
Posted July 26, 2006 - 06:21 AM
:thumbsup: I only have 300 km's om my WR450. It is a 2005.
I was wondering at how many KM'S does a normal break-In period officially end??
I am taking one more ride today, then I will change my oil!
So by the amount people saying I should check all orifices( HEHEHE) and drain the bike completely.
Any ideas??
Lit_dueler
  • Dube2
Posted July 26, 2006 - 06:33 AM
Hey lit_D,
Not sure what the difference is KM's to Miles are, however when new, I changed my oil after the first 8-10 hours, that's 2- rides. I figure that covers the idle factor and low speeds. Now I change the oil and filter after every three rides, usually works out to about 15-20 hours :thumbsup:
  • face_plant
Posted July 26, 2006 - 07:02 AM
i figure mine is pretty well broke in by now about 450 miles... km to miles 100km is 60 miles. first oil change 79 miles recomend 1/2 tank of fuel(mine was on the highway so low rpm crusing) changed filter but did not check screen (only 1 person i met has ever had junk in the screen until 15-30 tanks of fuel. as far as changing the coolant WHY? green lasts 2 years and nothing contacts it but the pipes and water pump.
2nd oil change 279 more miles no filter
from there i will do 500 and see what it looks like but you have to do oil changes frequently
  • SUnruh
Posted July 26, 2006 - 08:38 AM
while i can't say exactly on a wr450, i can comment with complete accuracy on a 06yz250f.
dump the original oil before the 1 hour mark.
dump it again every 3-4 hours.
at 16 hours of motor time (that should include spirited riding and all rpm ranges ie. a race) you will find that the wear metals in the oil have now stabilized.
and yes, i have multiple oil analysis to back this up.
that would the the *true* defination of "when is the motor broken in".
  • 06WR450FSM
Posted July 28, 2006 - 11:45 AM
I saw your posts on the oildrop forum a few weeks ago. Not too many people here are very lubrication savvy technically. The UOA's I saw from you were from racing with some cheap oils, right? Are you going to experiment with synthetics with the intent of extending your drain interval and slowing viscosity shear-down?
I'll go back and keep an eye on your UOA's. I plan to do one soon with those purposes for my application, which is 90% supermoto commuting.
Keep up the good work! :thumbsup:
