MY 06 smells like oil.
11 replies to this topic
  • Baron Von Beard
Posted July 24, 2006 - 09:14 AM
Since day one, my bike has smelled like oil after running it. Is this inherent of this bike or what? It's not smoking out the exhaust or coming out the vent tube, and I can't find any leak and the oil level is staying the same. What gives?
  • WFOracer
Posted July 24, 2006 - 09:32 AM
Mine smells like SC-1! :thumbsup:
Never noticed any oil smell....
  • jwcrf05
Posted July 24, 2006 - 09:47 AM
hey redbeard are you running rotella in there already, whenever I run rotella the bike seems to give of this distinct oil smell, my honda doesn't do it with the rotella but the yami does. if you use another type of oil the smell will go away , but I love the rotella so I just deal with it.
  • Baron Von Beard
Posted July 24, 2006 - 09:59 AM
Yep. I put Rotella in after the initial ride.
  • yzernie
Posted July 24, 2006 - 12:18 PM
If you don't rinse her off completely after a bath..................oh, nevermind.
  • adamdf
Posted July 24, 2006 - 06:54 PM
My 06 250F smelt like oil too, but when i checked, it was oil leaking from the oil filter because i didn't put the o-ring back in there. However, and i'm not sure if this is mental or not but i could have sworn i got that oil smell your talking about once or twice. Nothing is wrong with my bike though and no leaks, so i don't consider it anything but a nice scent on my bike, lol. just ride it!
  • FESTER
Posted July 24, 2006 - 07:24 PM
maybe you farted????? :thumbsup:
  • Reyndogg
Posted July 24, 2006 - 09:00 PM
make sure you have enough free play in the clutch lever - i had that smell a couple times then one day my clutch was smoked....
  • bigred455
Posted July 24, 2006 - 11:11 PM
I have noticed a faint smell of oil off of my 06 250 as well when stopped. I am going to say it is the vapors from breather hose coming off of the valve cover. Is the 450 set up the same way? I do not smell it anymore,it was the first few hrs of running it in.
  • eazrider
Posted July 25, 2006 - 06:27 AM
I have an '04, and an '06 450...They both smell like hot 90 wt. gear oil, or axle grease during a ride. I have used Yamalube 4str. oil and Rotella with the same results. When I first got the '04, I thought maybe I had a leak onto the exhaust some place. The '06 smelled exacly the same......dunno what the smell is. I have even had friends comment on it. Still waiting for the first valve adjusment to be needed on the '04....Go Blue..!
  • LJ
Posted July 25, 2006 - 08:10 AM
I switched to Rottella T also and now my bike stinks too.
  • Baron Von Beard
Posted July 25, 2006 - 08:21 AM
I thinks it's more pronounced on the Yami than on my Honda because the honda's breather tube was routed into the airbox and under the carb with a cap on it. With the tube coming down the left side of the frame, it will leak oil a bit and the smell is just pumped out.
  • Hot  47 replies
  • 10 replies
