wr 450 rebuild again? 6 200 km
1 reply to this topic
  • pops 56
Posted July 22, 2006 - 08:46 PM
After i replaced the gearbox parts and new rings (1200.km ago)There has been a bit more noise than before. Pulled motor down today. Just to be play safe, found that the flywheel side crank bearing is no good .There is a fair bit of movement side to side in the crank rod . A bit more than the manual says so the rod will need replacing. Question is do I replace the whole crank + piston with a aftermarket crank+ piston kit or use OEM again. Has anyone used a aftermarket crank+piston kit in there wr450. I will go with a complete crank as where I live It will take a while to send the crank away to be rebuilt. Please need some advice. :thumbsup:
  • Premo
Posted July 22, 2006 - 09:01 PM
Hey Pops!
Thought of getting a falicon stroker crank? Seeing as you are thinking about replacing and all......
http://www.faliconcr...com/yamyz45.htm
Looks a bit pricey though.
