wondering about big bore sleeve
7 replies to this topic
  • timothypg
Posted July 22, 2006 - 03:59 AM
86 xr6r. i would like to go to 100mm piston.my ? is, do the big bore cylinders (L.A. sleeve) have a larger o.d. than stock? i e-mailed l.a. and they said their kit has one bore, 100mm. IF that is the limit on their sleeve it must be the same size as stock therefore i would not change cylinders. has anyone dealt with this. thanks. tim
  • veetwo tls
Posted July 22, 2006 - 08:19 AM
you can rebore the standard bore for the wiseco or JE:100mm (630 kit) BUT YOU DONT have much meat left in the bore.
your best to get a 630 sleeve pressed in then you get 2 rebores.
  • timothypg
Posted July 22, 2006 - 08:23 AM
thanks for the info. that is exactly what i was looking for. what are the pages you have on your post out of? i can't see it well enough to tell. thanks again. tim
  • veetwo tls
Posted July 22, 2006 - 08:33 AM
try looking again i changed image hosting sites :thumbsup:
jeoff ballard's catalouge the guru of XR's here in australia.
http://www.ballards.cc/
  • timothypg
Posted July 23, 2006 - 03:45 AM
thanks veetwo. much better. i noticed ballards has their listing for 1988-on. all the places i look at here say that as well, i wonder why. mine is an 86. i do not have that nikasil coating on the cylinder. tim
  • veetwo tls
Posted July 25, 2006 - 03:19 AM
i presume you can still resleeve yours.
best bet to do is ring who ever does the kits over your side of the pond & explain what your after. info etc.
by the way if you go 630 use high octain fuel OR run 2 base gaskets to lower compression so you can run normal pump fuel.
  • timothypg
Posted July 25, 2006 - 06:52 PM
hi veetwo. the engine is still stock. i e-mailed L.A. sleeve and they say their sleeve for big bore is 100mm and can not be bored anymore, the one in your post w/ballards looks like it can be bored twice. do you know who makes that cylinder? the L.A. guys think my cylinder has nikasil, but it does not. thanks tim.
  • veetwo tls
Posted July 25, 2006 - 08:12 PM
i just spoke to ballards there gear is from USA through wiseco/JE (sleeves & pistons) there bore bores out to 630 max.
click on the first link of the 2 & look in the section above what i underlined (whats under lined was for my use at the time) section above XR600 (twin carb) 85-87 etc
hope this helps happy modding
  • Hot  29 replies
  • 22 replies
  • 9 replies
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
