2006 YZ450F Jetting
12 replies to this topic
  • dirtking
Posted July 21, 2006 - 05:23 PM
Hi guys and girls,
I am new to the site and just bought a new 06 450F. I live at about 1500' elevation and ride in 80-100 degree weather. Just wondering if the stock jetting is about right. Haven't broken in the motor yet maybe sunday!!!! Any help would be appreciated.
Thanks
  • barch88
Posted July 21, 2006 - 05:27 PM
Ride it and see what it does, most likely you will need to up the pilot a little, most of us had to go to a 48, but since it got hotter we moved down to a 45.
  • dirtking
Posted July 21, 2006 - 05:38 PM
Thanks for the advice. Hopefully break it in sunday or maybe tommorow cuz i pry wont be able to wait that long haha
  • Ga426owner
Posted July 21, 2006 - 05:39 PM
Hi guys and girls,
Thanks
Congrats you bought the best 450 out there but it does have lean issues from Yami :thumbsup:
It will be off guaranteed....go to a 45/48 pilot and 165/168 main jet and you will be happier about your purchase
  • dirtking
Posted July 23, 2006 - 10:21 AM
What series pilot jet is is for the carbs on these bikes? 21 or 22?
  • aford541
Posted July 23, 2006 - 03:31 PM
The Doctor Doug Dubach says 45 Pilot NFLR Needle on the 4th clip position 165 main. I tried that setup yesterday and it worked great.
I was running the 48 pilot and 170 main with stock needle in the third position. It worked pretty well but not too crisp off the bottom.
  • barch88
Posted July 23, 2006 - 04:23 PM
I'm running 48 Pilot with the stock 165 Main. Runs pretty good, still popping a bit, but a slight pop is normal. I may even want to lean it up to a 45, the plug is black...which means it's on the rich side.
  • dirtking
Posted July 23, 2006 - 07:14 PM
What elevation are you at and what temperature are you running in?
Posted July 23, 2006 - 08:06 PM
I'm runnning a 45 pilot and a 165 main with the stock needle. The bike runs fine in 80-90 degree weather between 2500-3500 feet I may try the NFLR, though. Dr.D is a smart guy.
  • aford541
Posted July 23, 2006 - 08:41 PM
I'm in So Cal, we went to I-5 MX
It was 98 F at 9:30am peaking at 110 F (it was stupid to ride!)
the elevation is 3811 Feet
I have power nows in both sides of the carb and a DMC pipe.
I just checked the fuel screw and it is 2.75 turns out, I think I need to reinstall the 48 Pilot jet for a lower altitude and cooler temps.
  • ben_suhard
Posted July 23, 2006 - 08:55 PM
He's a Yamaha test rider too!
  • dirtking
Posted July 24, 2006 - 07:40 PM
Can i get the pilot jets from dennis kirk? they sell 21 and 22 series pilot jets. Which one fits the carb on the 06 YZ450Fs?
  • SurvivorMan
Posted July 24, 2006 - 08:34 PM
I have never heard of Dennis Kirk. You have a Kiehin carb that takes a 42 pilot stock, which is very lean unless you are riding up very high altitude. Go to your local Yamaha shop and ask for a 45 pilot and a 48 pilot and you'll be set. oh yeah, and get a T-handle fuel mixture screw that is easy to access (this is at the bottom of your carb, it shows it all in your manual) The stock screw is impossible to get at so quick trail side adjustments are virtually impossible. Good luck!
  • Hot  47 replies
  • 9 replies
Motocross
  • Hot  491 replies
