Clutch adjustment problems
1 reply to this topic
  • woods-rider
Posted July 19, 2006 - 12:07 PM
ok, so i took off my clutch cable from the lever to lube it up then put it back on and adjusted it to the proper amount of lever free play. now when i pull the lever it doesnt engage the clutch hardly. its still pulling the cable down at the spring where it goes into the engine. any help?
  • Beejay
Posted July 22, 2006 - 06:50 AM
Check the free play adjustment again maybe the cable is stretched & you need more adjustment, you shouldn't have clutch probs after what you have done.
