Works Connection glide plate mod - 06 YZ450
5 replies to this topic
  • yzernie
Posted July 17, 2006 - 08:10 PM
I got a WC glide plate for my 06 YZ450 and the first thing I noticed was that I could not get my fingers into the hole on the right side to change the oil. I did not want to have to take the plate off every time I changed the oil so I decided to modify it.
I ended up making the hole 3" overall from front to back and widening it 1/4" on the engine side and about 1/8" (or less) on the frame side. Now I can easily get a wrench and my fingers to easily reach the drain plug.
Hope this helps.
  • Merc1212
Posted July 19, 2006 - 05:17 AM
The std hole is too small... I can manage to get it out, but it takes twice as long as it did without the plate. I figure one of those new ratcheting wrenches might just do the trick though. If not, I'll consider taking a saw to it as well.
Cheers,
Marc
  • DPW
Posted July 19, 2006 - 06:52 AM
T-handles...loosen three bolts and the plate is off..
The larger hole is a good idea though.
  • tjp26
Posted July 19, 2006 - 01:21 PM
I did pretty much the same thing to mine, it's much easier to change oil now.
  • Reyndogg
Posted July 19, 2006 - 02:16 PM
I have my WC plate sitting on my bench right now, i have traced the outline of the stock plate and had planed to get someone to cut it for me b/c a dremmel is all i have to cut it and it would take forever with that!
Your design seems much easier...i may try that.
re: racheting 12mm - tried that, it is a bit easier but in the end, not a whole lot better.
  • FriscoKLR
Posted July 19, 2006 - 03:09 PM
Lightly press the bolt to the threads with your index finger and spin it in with your middle finger. More than enough room.
  • 0 replies
  • Hot  36 replies
  • Hot  30 replies
  • Hot  113 replies
  • 10 replies
