Xr600 Horn
3 replies to this topic
  • thunderhog
Posted July 17, 2006 - 11:25 AM
Anyone have any info on how to wire a horn into my 93 xr600? I got an old horn off an xl350. If I were wiring a house, I would find a feed and run it to a switch then run from there to horn. Is it a similar deal with motorcycle wiring? I'm trying to get the bike plated, so need a horn. Thanks
  • theron19d
Posted July 23, 2006 - 02:01 PM
I took a horn off of an old DT400 I had and wired it in but the switch was already there on my BD kit.
  • creeky
Posted July 23, 2006 - 03:44 PM
The XR600's alternator will not have enough butt to blow the horn. It will work if you replace the voltage regulator with a 12V regulator/rectifier and wire in a battery to act as a ballast.
  • bork
Posted July 23, 2006 - 08:10 PM
I strapped a mini air horn on handle bars from walmart marine section. $6.95?
  • 9 replies
Honda XR650L 2017
  • 0 reviews
  • 17 replies
  • 22 replies
  • Hot  60 replies
