Best dirt dual sport
26 replies to this topic
  • kelleyseiler
Posted July 20, 2006 - 05:20 AM
#21
I got my XRL in September 05. I have done the carb mods, uncorked and new exhaust on it. I love it! There are a couple of complaints with it like the small fuel tank and high seat height but I have lowered it with a performance lowering link, I just wish the tank were 4 gallons! I have owned a DR650 and I hated it, had way too many problems with the engine. I have also owned a couple of XL250's and loved them. The XRL is pretty easy to work on as long as you have some basic mechanical skills. Not much goes wrong. Good Luck!
Here are a couple of pics of mine.
http://i43.photobuck...ler/XR650L3.jpg
http://i43.photobuck...50/HPIM0300.jpg
http://i43.photobuck...ler/XR650L1.jpg
  • Muddin
Posted July 20, 2006 - 07:33 AM
#22
What muffler is that on your bike kelleyseiler. Did it fit right on without modifying anything, and how does it sound? I have been thinking of a Supertrap but open for suggestions.
  • goblin127
Posted July 20, 2006 - 07:47 AM
#23
Sound's like the XRL is the bike you need.
  • kelleyseiler
Posted July 20, 2006 - 10:42 AM
#24
It is a Wileyco Stainless for a XR600 but it fit on perfectly,they are interchangable. Installed in about 15min. Heres a Pic from underneath. It sounds Great!
http://i43.photobuck...0/pipeunder.jpg
  • SniperTeamBravo
Posted July 20, 2006 - 11:46 AM
#25
If you want a 4 gal tank, I am selling my 4.7 gallon Acerbis plastic tank for $100.00, but youd need to buy the XR tanks mounts to fit it to your XRL I "think" Im not sure what the tank mounts look like on the L, are they built into the tank?
  • kelleyseiler
Posted July 21, 2006 - 07:38 AM
#26
THE STOCK TANK HAS THE SLIDES BUILT INTO IT. HOW DOES THE ACERBIS TANK MOUNT?
  • veetwo tls
Posted July 21, 2006 - 08:20 AM
#27
XR600R cant go wrong mine 1992 has done 307,000 klm.(my every day ride. work & play)
i drop the oil & filter every 3,000 klm rebuild top end every 30,000 klm intervals & at 60,000 klm intervals top & bottem end inspection/rebuilds
just rebuilt the bike ground up 5,000 klm ago $10,000AUD
MODS:
je:630
corillo rod
head ported
valve seat grind
rockers hard faced
mild cam
silicon valve springs & bronze valve guides
mikuni 38mm flat slide carb (should had got kehin)
CRD header pipes
barrett C/F muffler
hi temp valve seals
w/b heavy duty clutch springs
eibach F & R
k&n
200w lighting
seat (custom cover & higher foam in the mid section)
renthal twin wall
tag metals bar raiser mounts
custom oil cooler (cut down car auto trans cooler)
custom crank breather/oil return
custom bash plate,R/brake & R/sprocket shark finn & rear brake m/c guard
chain gang sprockets
REBUILD:
new heavy duty wireing right through
powder coat frame
stearing bearings
main bearings
crank (3 cracks)
counter shaft
3rd gear
valves
complete clutch basket
c chain guides
standard big bore top end deck bore & hone rebuild
gaskets
bearings
swing arm rebuild
etc etc
and now FOR SALE south aussies if anyone interested.
  • 4 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  186 replies
  • Hot  60 replies
