Back rack on DRZ-E
6 replies to this topic
  • Christian
Posted 26 April 2002 - 09:10 PM
Does anyone has a back rack for the DRZ-E,
I've already seens the SRC one and the one in dirt rider but they run at $170.
Kind of expensive. Any other solution ?
Thanks
christian
  • prohaska
Posted 26 April 2002 - 10:43 AM
Don't get the SRC rack. The handles broke off the first time I tried to pull my bike out of a mudhole. Kind of a pain to install, mounting holes didn't line up all that good. Check out the archives.
  • Roadwarrior
Posted 26 April 2002 - 11:41 AM
I had the same dilema as you, so I decided to make my own rack from mild steel tubing. It looks pritty good, and is braced from the bottom. Hope the pictures show up, so you can see.
  • MXMAICO
Posted 26 April 2002 - 12:49 PM
Roadwarrior, nice job! Do you have any sketches or plans that I could copy?
  • Christian
Posted 26 April 2002 - 01:25 PM
Oh waouh, great job, I think I'll check with my neighboor, he does welding stuff.
Thanks
christian
  • Weekend_warrior
Posted 26 April 2002 - 01:29 PM
You do excelant work. Looks cool!
  • Roadwarrior
Posted 26 April 2002 - 05:58 PM
I don't have any plans. What I did was first bend up some copper pipe into shapes until I was happy. Then I bent up the steel tubbing to match the copper pipes I bent by hand. Since I don't have a tube bender, I used a small pulley mounted in a vise. I would heat the tube with a tourch, and bend it arround the pulley a little at a time to avoid kinking. It worked great, and the tube looks mandrel bent. The mounts at the seat bolts are made from larger diameter tube with a washer welded at one end. Make sure to fishmouth the end for a nice tight fit so that the welding will be easier. Just take your time, and if you mess it up try again from the copper patterns you made. The rack cost me next to nothing to make, and it looks better than the billet racks.
Sam
If you enjoyed reading about "" here in the ThumperTalk archive\, you\'ll LOVE our community. Come join ThumperTalk today!
