reduceing handle vibration
11 replies to this topic
  • timothypg
Posted July 16, 2006 - 01:59 PM
my fingers fall asleep after about 5 mi. drives me crazy. does anyone think filling the handle bars with expanding foam will cut down on this problem.
  • Jon-D
Posted July 16, 2006 - 02:41 PM
try running a set of Flexx bars, they helped me alot.
  • justicedone
Posted July 16, 2006 - 02:53 PM
Even a change of gloves and grips may help for the money spent...
just a thought
  • timothypg
Posted July 16, 2006 - 03:17 PM
i tried some new grips, forget the name but they are supposed to have jell, no help though. i'll look at the flexx bars.
  • TREADMARKS
Posted July 16, 2006 - 03:26 PM
I use flex bars, barsnake, Gel grips and gel gloves.
  • motomonte
Posted July 16, 2006 - 07:02 PM
you can also try leaded weights tha fit at the end of the handle bars,chek in the cruiser parts areas,they should know better....
  • XR 650
Posted July 17, 2006 - 03:13 AM
ProTaper Contour bars took alot of vibration out (amazing how much) & Pro Grip Gel grips helped a good bit.
  • JDR
Posted July 17, 2006 - 05:20 AM
I have exactly the same problem. Very annoying. I have stock bars and grips on my XR650R 06'. It was suggested to me to try softer thicker grips and fill the bars with silicon. I am going to change the bars and bar height anyway, but will try the grips first. Let me know how you go.
  • SniperTeamBravo
Posted July 17, 2006 - 07:08 AM
I did the exact same thing on my XR600R and it worked great but also do a barsnake and it'll be unbeleivablely better. Good luck!
  • Boudroux
Posted July 17, 2006 - 11:18 AM
Get a set of fastco antivibration inserts. They have been working great in my KX250 pinger.
  • Jon-D
Posted July 17, 2006 - 12:15 PM
If you want to go to the extreme, you can pull your crank/piston and have it balanced. I noticed a slight improvement in a friend’s KTM on vibration (which was not that noticeable to begin with) and the bike revved faster. I am thinking about doing this next winter if I decide to rebuild.
  • timothypg
Posted July 17, 2006 - 03:37 PM
all good ideas. thanks. i was thinking about the silicone thing also, or maybe some cork? the flex bars look good but a little pricey. the pro tapers and bar snake look good too. it get's dangerous shakeing my hands back to life when i'am in heavy traffic, gotta do something. tim
  • Hot  60 replies
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
  • 4 replies
