squirly rear tire
9 replies to this topic
  • quailboy
Posted July 15, 2006 - 01:28 PM
i just got my 99 yz400f running. first time on a big race four stroke and i notice that even on pavement(worse on dirt) that the bike tire goes a little squirly while accelerating. do i need to just deal with it or put more weight on the real wheel? any suggestions? i tried the search thing and didnt find anything. thanks
  • bg10459
Posted July 15, 2006 - 01:50 PM
What tire? What pressure? What condition is the tire in?
Also check that the wheel is properly aligned.
  • quailboy
Posted July 15, 2006 - 01:52 PM
new tire not sure what brand. when i put the tire on the side with the chain is a fraction of a fraction of a inch to far back. will that change anything? and do i want less pessure for more traction or what?
  • yamahacrazy_310
Posted July 15, 2006 - 02:10 PM
You have to much air pressure in the tire. Put only 12 psi in the tire and you should be fine. Run both front and rear tire at 12 psi.
  • quailboy
Posted July 15, 2006 - 02:11 PM
thank you i will try that. i wont bend my rims or anything i do some pretty tough trails. i dont really ride on the track
  • yamahacrazy_310
Posted July 15, 2006 - 02:19 PM
No you will be fine. I only run 12 psi in my tires and I ride track and trails.
  • Jaycycle
Posted July 15, 2006 - 02:35 PM
Put the bike on a stand. Try to wiggle the rear tire back and fourth. If it wiggles then you need new bearings. If it doesnt then try what everyone else has said. My .2 cents.
  • quailboy
Posted July 15, 2006 - 02:58 PM
just got new rims tires and bearings i think its the tire pressure cause the shop i took them too pumped them up and they felt pretty hard. thanks everyone
  • NYMXer
Posted July 15, 2006 - 03:50 PM
Also try running a gear higher than your used to. It's not a 2 stroke so it will pull w/ torque rather than revs. :ride:
  • theclone
Posted July 16, 2006 - 03:57 PM
they pump it up to like 30 psi to seat the bead. :ride:
  • Hot  36 replies
  • On January 15, 2017
  • Hot  50 replies
  • Hot  113 replies
