Valve/Cam pictures
5 replies to this topic
  • Dustin_Mabro
Posted July 12, 2006 - 07:49 AM
I was checking the valves on my '00 yz426 sunday and came up with really tight measurements. Since i haven't anyone that has ever done this before i was wondering if anyone had pictures with instructions. I used the motoman instructions but am second guessing myself.
I did find pictures a couple weeks ago that went along with a few instructions but they have since been taken down.
Thanks much
  • DrThumper
Posted July 12, 2006 - 12:53 PM
Its been awhile since I checked my valves, but as I recall it was pretty straight forward. I do remember that I had to pull out my long feeler guages, the short ones (like I use for spark plugs) were just too short and the hanlde was in the way.
The 2000 426 has steel valves. I did an adjustment on them once, a long time ago, then I used to check them like every 6 months for 3 years or so, and they were always in spec. I don't think I've even looked at them for over 18 months. The 01 and later models, like the CRFs have titanium valves and need to be checked, adjusted, and replaced quite often.
  • DrThumper
Posted July 12, 2006 - 12:54 PM
By the way....it just isn't right, unless theres more cowbell.....
Posted July 12, 2006 - 03:00 PM
This Link is for a 250F, so forget the clearance specs you see and use the ones from your manual. The pictures, though, may as well be of a 426, they are so near the same.
  • Slowmotion426
Posted July 12, 2006 - 03:03 PM
I've had my '01 for 5 years now, and have only had to adjust the valves once. :ride:
  • Dustin_Mabro
Posted July 13, 2006 - 04:19 AM
sweet, thanks grayracer. thats exactly what i was looking for.
I like pictures and those helped me to realize i did go through the procedure correctly. Unfortunately now knowing that i measured the clearance correctly now tells me that i have to re-shim the valves :ride:
more stuff that I've never done
THANKS GUYS :ride:
  • Hot  36 replies
  • 0 replies
  • Hot  47 replies
Motocross
  • Hot  491 replies
