05 CRF 450 front axle nut
18 replies to this topic
  • offshores
Posted July 11, 2006 - 03:25 PM
What size socket for an 05 CRF 450 front axle nut. Thanks
  • NorCalRider
Posted July 11, 2006 - 03:28 PM
Hmmmmm........25mm? Sorry, I'm not 100% sure. All I know is the rear is 32mm or 1 1/4". :ride:
  • motofix
Posted July 11, 2006 - 03:49 PM
I belive it is 22mm
  • Joe Dizzle
Posted July 11, 2006 - 08:31 PM
You sure motofix? I have a couple of snap on hex sockets and I thought my 20 and 22mm were too small. I'll check in the morning.
  • crf-f crf-r trx cbr
Posted July 11, 2006 - 08:48 PM
22mm :ride: :ride:
  • ShadyatBest
Posted July 11, 2006 - 09:26 PM
22mm :ride: :ride:
fo sho
  • AZ Thumpdaddy
Posted July 12, 2006 - 03:38 AM
It is nearly the same as a 7/8" standard size or 22 mm.
  • gofast33
Posted July 12, 2006 - 03:43 PM
Is it normal when tightening the front axle nut for the fork leg to creep in toward the hub a little? This happens no matter how much I tighten the two pinch bolts on that side. I'm always concerned that the nut will loosen off during riding.
  • motofix
Posted July 12, 2006 - 05:43 PM
Try tightening the nut first, then use the two pinch bolts to hold it. After you have that, you can align the right side.
  • gofast33
Posted July 12, 2006 - 10:27 PM
Aaah, that makes sense! So, do you temporarily tighten the right side pinch bolts to keep the axle from spinning while you tighten the axle nut, then loosen again, tighten the left side pinch bolts, then center forks and re-tighten the right side pinchers?
  • philbrooks
Posted July 13, 2006 - 12:58 AM
Tighten the axle nut till axle begin to spin. Then tighten pinch bolts on left side (facing bike) Then tighten axle nut to spec's, then tighen pinch bolt on right side (brake disc side)
  • motofix
Posted July 13, 2006 - 04:04 AM
You got it. :ride:
  • motofix
Posted July 13, 2006 - 04:06 AM
sorry that didn't work the way I wanted. but yes, you got it
  • Joe Dizzle
Posted July 13, 2006 - 02:59 PM
Torque the axel nut first with out tightening any of the pinch bolts. Once the axel nut is set then grab the front brake lever and compress the forks up and down a few times. Then tighten the pinch bolts to spec. (This is the proper way my man)
JD
  • motofix
Posted July 13, 2006 - 04:06 PM
That is one of many ways actualy... :ride:
  • Joe Dizzle
Posted July 13, 2006 - 08:25 PM
I suppose you anyone could say the "best" way to do something is one of many ways yes. Hows it feel to be right?
Some people..... :ride:
  • motofix
Posted May 03, 2013 - 01:47 PM
How about using an allen key to hold the axle while tightening the nut? I would say that is the proper way to do it, but your way works too.
  • Toooldtooslow
Posted May 03, 2013 - 03:40 PM
My suspension tuner showed me how the slight burr on the axle head (from prev owner) made the fork bottoms pull to gether when the axle was tightened up. This make the front suspension harsher as the travel is used as the forks become like a slight vee. he machined the burr off the axle so it seated in fully.
  • joman2055
Posted May 03, 2013 - 10:56 PM
you are supposed to torque the axle before tightening any of the pinch bolts. this requires a special tool for the large hex in the axle.
then you tighten down the non nut side pinch bolts, cycle the forks or spin the wheel a few times and hit the brakes. then tighten the other pinch bolts.
at least im pretty sure that is the correct way.
02 crf450r smoking after rebuild by bigg_stevee
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  43 replies
First real bike, need help. Husqvarna 450 or CRF 450 by zander
  • 3 replies
Jetting help for my popping backfiring nightmare by Budstang
  • Hot  57 replies
Did I make a bad choice? by 01cr250.677
  • Hot  39 replies
CRF that has been sitting for 6 or 7 years, is that safe to buy? by deanevo
  • Hot  36 replies
