Zip Tye Problems - Please Help !
12 replies to this topic
  • jecsr
Posted July 09, 2006 - 04:08 PM
I have a zip tye screw that once I back it out more than 1 1/4 turns, it real loose and backs it self out while running. I need to get it to 2 1/2 turns but I am afraid that I would loose it. Has anyone else had this problem ? I tried using the search engine, but it is down right now.
  • NYMXer
Posted July 09, 2006 - 04:19 PM
Is the O ring and spring in place? :ride:
  • seizedcrank
Posted July 09, 2006 - 04:24 PM
zip tye?
  • rsj450
Posted July 09, 2006 - 04:29 PM
zip ty fuel screw that whats they are referring to
  • jecsr
Posted July 09, 2006 - 04:36 PM
Yes, everything is in place. At 1 1/4 turns it tight and does not move. Anything past that and you can wiggle it back and forth and it is real loose.
  • flintlock28
Posted July 09, 2006 - 04:47 PM
Whenever you install the Zip-TY fuel screw, you are suppossed to stretch the spring out a little bit so that it keeps constant pressure on the screw, preventing it from backing out.
Go ahead and take the whole assembly out, and stretch the spring just a little bit, so that you are making it longer than normal. This will now allow the spring to keep tension on the screw, and she'll no longer back out.
  • jecsr
Posted July 09, 2006 - 04:52 PM
I will give that a try. Thanks for everyones help !
  • Reyndogg
Posted July 09, 2006 - 06:07 PM
that seems kinda hokey to me... the MSR i bought works great out of the box, which is how it SHOULD be IMO :ride:
  • stillsun
Posted July 09, 2006 - 06:35 PM
Forget the quick adjust fuel screws, pick up one of these and don't worry about screws falling out.
http://s7.sears.com/...l=2.56&fmt=jpeg
  • flintlock28
Posted July 09, 2006 - 07:11 PM
Hey Reyn, You're right it is kinda hokey..but I read too many cases of people losing their fuel screw out on the track/trail. So the general consensus is to stretch the spring a little. I've had no problems since install, but it should have been mentioned in the instructions, or corrected with the design.
  • Reyndogg
Posted July 09, 2006 - 08:23 PM
good point...it's better to have to do a little spring stretching than lose a fuel screw, thats for sure.
  • MotoGoalie
Posted July 10, 2006 - 06:38 AM
How hard is it to stretch a spring? FFS. :ride:
  • getdrunk
Posted July 10, 2006 - 11:07 AM
put a spring on the screw. i have a carb ike that. it has a spring on it so that their is presure pushing on it and that stops it from backing from viberation.
  • Hot  47 replies
  • 9 replies
  • 0 replies
