put a yz fly wheel on a 04 wr 450?
6 replies to this topic
  • BIG TDM
Posted July 08, 2006 - 07:11 PM
I want to put a lighter fly wheel on my 04 wr 450. can you just get a fly wheel off a yz and put if on there? if so what year and size? and has anyone out there done this, and what kind of results have you seen? :ride: :ride:
  • mtrablue
Posted July 08, 2006 - 08:41 PM
the wr and yz have different ignition designs. they don't interchange. do a search but look for something along the line of "lighter flywheel". i think trailtech makes one but it's only a few ounces lighter. are you still using your e-start? if not you can remove the starter clutch from the back of the flywheel and take a few ounces off.
  • BIG TDM
Posted July 08, 2006 - 08:47 PM
yes I STILL WANT TO UES E BUTTOM JUST NEED IT TO WIND OP FASTER. AND I WOULD LIKE TO GET RID OF ALOT OF ENG. BREAKING. CHANGER THE GEARING BUT NEED IT TO WIND FASTER.
  • mtrablue
Posted July 09, 2006 - 09:26 AM
turn off the caps lock. no reason to yell at me. just trying to help. do the search. if i remember the thread, the only solution was the trail tech flywheel. even that was only about 4 oz. lighter.
  • Indy_WR450
Posted July 09, 2006 - 01:59 PM
Put in a YZ exhaust cam first. That and the gray wire mod will make it rev out quicker. :ride:
  • 06WR450FSM
Posted July 10, 2006 - 10:56 AM
My new Trailtech catalog has a 6-oz lighter one. But that only gets you about half way down to a YZ. Give Trailtech a call and see what they can do for you...
  • pkcof
Posted July 10, 2006 - 11:39 PM
if you add a decent pipe, open the airbox, unplug the grey wire and jet it correctly it will spin up plenty fast - it is a WR, not a YZ. You can get it close but it was still built as a WR.
If it had no button, no battery, less flywheel weight, way open airbox, de-restricted pipe, racing timing, racing cams and a close ratio gearbox it would spin up faster still - it would also pretty much be a YZ
Maybe you want one of those?
