counterbalancer
10 replies to this topic
  • ChaosX
Posted July 07, 2006 - 02:30 AM
I have noticed a razzle and ticking sound on my YZ400 98:a. There is this razzling sound on idle. I did a search here and i do believe its the key for the counterbalancer.
But, if its the timingchain, how can i notice the differences? Can i listen to the sound?
This razzle sound is all trough the register and i do believe it do come from the clutchside on the engine. If i replace these, should i replace on both sides?
Posted July 07, 2006 - 04:11 PM
Pull the clutch in and see if it goes away. Put it in gear if necessary. If it gets quiet when in gear, but rattles in neutral, odds are it's normal transmission torsional rattle, and nothing to worry about.
  • Butta
Posted July 08, 2006 - 06:22 AM
If you haven't replaced the timing chain, now's a good time to do it. Doesn't take that long, and is very cheap (like less than $20), and it's good insurance. Check the workings of the auto chain adjuster while you have it off.
  • rexbond007
Posted July 08, 2006 - 08:23 AM
if you find it hard to start when it is hot , most likely it would be timing chain.
Posted July 08, 2006 - 10:36 PM
You're right about the priice of the timing chain...for a 450. But the older bikes are about twice as expensive. No clue as to why.
Really? How's that work?
  • rexbond007
Posted July 09, 2006 - 12:22 PM
When my Timing chain was Stretched and in need of replacing ,on my WR 250, I found the bike hard to start Hot as well as cold.even more so when Hot.the mechanic that did the work said that was one of the signs of wear as well as noise.
Posted July 09, 2006 - 08:40 PM
The only thing that a timing can do is to accelerate wear on the crank sprocket and retard the timing of the cams by being longer than it should be between the crank and cams. In order for the chain to have a negative effect on starting or low speed performance, it would have to have been stretched enough to retard the cams nearly a full tooth. Not frankly very likely.
Your mechanic was feeding in a little extra color to make his work seem more worthwhile to you, IMO.
  • ChaosX
Posted July 09, 2006 - 10:17 PM
First, i have tried this with the clutch but it still make noise.
I did remove my tensioner and the piston did move really fine. When i reinstalled it i noticed that it is more than the half piston left before it has reached the bottom.
Two, my bike starts really fine, cold or warm... No problem at all.
If i do change my camchain, is that an operation that i can do by myself?
If so, is there any good tip u can give me?
Thanx for all the help guys!
Posted July 10, 2006 - 07:32 AM
You can do either operation by yourself if you can adjust valves. The balancer gear is under the right engine cover, on the end of the crank. The same nut holds both the primary gear and the balancer drive gear in place, but the balancer gear has a square key to keep it located, and the key loosens up. Some have decided that the stock key fits too loosely, and have filed down a piece of square key stock to make their own. Bear in mind, the balancer is timed to the crank. See the manual.
The cam chain is a little more involved, and you will need a torque wrench for the cam caps, and a flywheel puller. On the '00 models and newer, you need a Torx bit to remove the stator plate; I suppose that to be true of the 400 as well.
Here's a post by an old grouch about how the procedure goes. It's not a bad write up, in spite of the guy who wrote it:
http://www.thumperta...405#post3150405
  • ChaosX
Posted July 10, 2006 - 12:45 PM
Thanx Grayracer!!!!
I did read that and thats to much for my skills. I am going to replace the camchain before i will ride next time.
Btw, does TT ship overseas? I do live in sweden an are intrested in that 450 camshaft.
  • tom nolan
Posted July 11, 2006 - 07:09 AM
I had a noise deep inside the engine on my 98'. It ended up being the crank bearing going south. I had a pulsesation just above idle speed. There were also fine particals of metal in the filter. After changing the crank bearing, all my noises went away. The ballancer is fairly bullet proof, at least that's what I have found out.
  • 9 replies
  • Hot  47 replies
  • Hot  33 replies
