how do i start the damb 426!!!!!!!?
81 replies to this topic
  • getdrunk
Posted July 05, 2006 - 04:08 PM
i hooked every thing up. i put gas in it. i have no air filter and no oil and no coolant in the motor. i never had it running and just want to make sure it runs.
so how do i start it. i been kicking it for 10 mins not even a pop. its like 70 degrees out right now.
  • Javelin
Posted July 05, 2006 - 04:09 PM
Dew whut?
  • jamieyz426f01
oh dear...
  • crfmatt
Posted July 05, 2006 - 04:11 PM
PUT OIL IN IT! Also fill the coolant to. Then once ALL of your fluids are good push the kickstart lever down till it stops and then let it come back to the top and push to make sure its at top dead center. Then pull the decomp lever and bring the kickstarter down like an inch or 2. Then let go of the decomp lever and bring the kickstarter back up and then kick it through. If that doesnt make it fire after a few kicks put in a new spark plug.
  • getdrunk
Posted July 05, 2006 - 04:12 PM
searicly how does this thing start. it wont. its getting spark. i put gas in it and a little in the cylinder. need help fast
  • getdrunk
Posted July 05, 2006 - 04:15 PM
well doesnt it start with or with out oil and coolant? i dont see why not. i jsut want to here it run so i no it does run. its used and i never started it.
thats the decomp lever? i have a red and a black dials on the carb
it has a bran new plug
  • barch88
Posted July 05, 2006 - 04:17 PM
It will seize up if there is no oil in the engine! Please, for the love of God put oil in the engine, and coolant in the radiator. Check spark plug, change it, try it agian. If it seizes up you really won't get it started... :ride:
  • getdrunk
Posted July 05, 2006 - 04:18 PM
hows it gona sieze??? ill only be running for like 5 secs just so i no it will run then ill pull the kill switch
  • barch88
Posted July 05, 2006 - 04:19 PM
Just put oil in the thing...if it doenst work with oil, worst that can happen is you lose a quart of oil and not a entire engine.
  • Bigcr
Posted July 05, 2006 - 04:20 PM
:ride: :banana: :ride: :ride: :p :p :ride:
  • getdrunk
Posted July 05, 2006 - 04:22 PM
i dont got no oil. my friend ran a quad on no oil for a day and it snapped a rod from the heat but it wont run long enough to do that.
i cant put water in it cause i got no radiator yet
  • getdrunk
Posted July 05, 2006 - 04:23 PM
well im gona try agaiin. bye bye bye bye bye bye bye bye bye bye
  • barch88
Posted July 05, 2006 - 04:26 PM
If you don't have oil, radiator, or complete ready to run engine, DON'T TRY TO RUN IT UNTIL YOU DO.
Damn.
  • Bigcr
Posted July 05, 2006 - 04:36 PM
You're killing me dude! You ask for advice, then you don't want to take it. Lay off the bottle and learn to use the English language.
  • GreenKLX
Posted July 05, 2006 - 05:08 PM
ahh, just use olive oil, its just as good. And put ice in the exhaust pipe to give the same results as coolant in radiators.
al oli is teh sam damb carp riht :ride:
Everytime this guy posts, I feel bad for quad riders everywhere. :ride:
  • Junior426
Posted July 05, 2006 - 05:30 PM
Not to be offensive, but you deserve to be shot. I hope that you seize the motor and are unable to fix it ever. You are a disgrace to youth and to quad riders. I hope you have bad luck, you are the most ignorant person I have ever read of. :banana: :p :ride: :p :ride: :ride:
  • ridered55
Your a knucklehead!!!!
  • Numskull
Posted July 05, 2006 - 05:45 PM
Tie a rope to your chevy bumper and the other end to your handle bars. Have your buddy pull you down the interstate at 65mph. Put it in first gear and release the clutch. If it dont start, there may be a problem somewhere you need to fix. But thats the best way to get any 426 running, good luck :ride:
  • felix4x4
Posted July 05, 2006 - 06:26 PM
Just post some pictures and part it out... You will be happier cause starting that 426 is a real pain. Then again you could always just put some freeking oil in it so the thing gets the proper seal and compression. Then maybe just maybe you will listen to the person that posted the timing sequence for this particular bike. And hot farking dam the thing will spring to life.
  • getdrunk
Posted July 05, 2006 - 06:39 PM
i had it running. it sounds awsom. its one LOUD mofo. i figerd out how to kick it.
it has alot of white smoke though. maby theirs dust on teh piston from sittin 6 months. idk hopfuly its not teh rings
  • On January 15, 2017
  • Hot  28 replies
  • Hot  38 replies
  • Hot  36 replies
