Bugstain said:
Except that at TDC on the exhaust stroke, the exhaust valve would have just finished closing (watch as you turn the engine to TDC), and the inlet would be opening, or getting ready to open.
On the compression TDC, both valves will be closed long before you get there, and will remain closed long after you pass TDC
The easy thing is to watch the cam lobes for the last 90 degrees or so of crankshaft rotation as you crank the engine toward TDC - if there is no valve activity, you're approaching the compression TDC. If either of the valves is opening or closing, you're on the wrong stroke.
I realise this, but the head has been off, so I could put the cams back on at ten and two, i.e TDC of compression, and the bottom of the engine, could be on it's exhaust stroke.
The cdi doesn't know someone has been moving things around.
Am I missing something here or what, surely there is only one spark per two revolutions of the engine - hence 180 degrees out.
