Jet Location
2 replies to this topic
  • SXP
Posted July 04, 2006 - 09:41 PM
On an 04 carb should there be two jets in the mouth of the intake bell? I'm seeing two holes one of which is threaded and has a jet in it. The other is just a hole. Having said that, where are the Main Air Jet and Pilot Air Jet located? Thanks.
  • Thumper_Bloke
Posted July 05, 2006 - 07:31 AM
Check this out, i dont know if it will help....
http://www.sudco.com/fcrmx.html
  • bg10459
Posted July 05, 2006 - 07:46 AM
As you look at the airbox side of the carb, the PAJ is on the left and is removeable. The MAJ is on the right and is fixed; #200, I think.
Unless you're playing with the ACV, you shouldn't need to change the PAJ.
