what does it "need"?
7 replies to this topic
  • Way Fast Whitey
Posted July 04, 2006 - 08:46 PM
i have read that many owners feel they need new:
chain/sprockets
silders, wear plates
tires is a must
and higher bars
am i missing something? i'm trying to figure out out i'm goign to be spending afterwards.
thank you :ride:
  • Bigcr
Posted July 04, 2006 - 09:05 PM
As long as the suspension is set up for your weight, it "needs" your right wrist to twist! :ride:
  • barch88
Posted July 04, 2006 - 11:46 PM
Stock sprockets are fine if you change the chain right away. I use stock sprockets with aftermarket chain.
Slider or wear plate is a good idea, I ordered the TM one, but it's still out of stock, but I checked mine today after riding a good 15 hours on my bike so far, and it's not even worn at all, so I may cancle the TM Slider and save 80 bucks.
The stock tires work good FOR MY TRACK, but A LOT of people had to change them out, the front is exactly what I need for my track though!
I personally like the stock bar bend, maybe because it's the only other bar I used besides my old stock TTR bars...so I guess Im just used to it?
Suspension, is great on this bike, best factory suspension. I set my sag, played with clickers a tad, and it feels really great.
So the only MUST is a chain, everything else is just extra. Possibly jetting for you though? I had to rejet mine.
  • Way Fast Whitey
Posted July 05, 2006 - 06:40 AM
thanks barch88, i have been reading this forum for over a month now, and it seems that i will need to riched the pilot slightly, no big deal, but i won't order anything until i ride the bike. if it comes with the chain that came stock on a 2004 YZ250F, it is going in the garage in a big hurry.
i saw someone put silicone around there wear plate, that would work if it was starting to wear the swing arm a bit.
thank-you
  • Ranger18
Posted July 05, 2006 - 07:13 AM
You should also consider protecting your investment.
Devol Skid Plate
Devol Radiator Guards
Cyrca front disk cover
And make sure your levers are loose enough to move around during a crash.
For sure new chain. I think if you put a good chain on right away then you don't even have to worry about the chain slider.
  • chrisl609
Posted July 05, 2006 - 09:14 AM
I agree with the additional protection items, here is what I have done to mine:
Regina O Ring gold chain (Threw on before first ride)
GTYR water pump guard
GTYR master cylinder guard
Devol radiator guards
Things I want to get next:
GTYR bar risers or maybe Applied top clamp
+1 rear sprocket
45 pilot jet (pops a little on decel)
Also, be sure to grease up everything before you ride it. Mine had very little grease on anything!
  • aford541
Posted July 05, 2006 - 10:14 PM
Jetting: 48 or 45 Pilot 170 main depending on power now, fuel, altitude, adjustable air fuel screw.
Chain: stocker stretches and kills the sprockets right away chain only will do.
Tire: 739 sucks brand new.
Lower the fork tubes to the line and set sag at 100MM
Higher bars: stockers are almost an inch lower than the Windham bend
Suspension: perfect if you are 160, re spring and re valve it.
The 07 has a different CDI box, 1.5 mm longer shock, quiter muffler, wave rotors, thinner fork tubes (same internals), forged triple clamp (not cast)
  • howard27
Posted July 07, 2006 - 06:54 PM
Applied triple clamp set 27mm glues the front end back down. ( forks flush)
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
