Play in Front Brake Disk
7 replies to this topic
  • yami racer
Posted July 04, 2006 - 04:04 PM
I have a small amount of play in the disk on a 2006 YZ450F. If I lock the front brake the front tire will shift back and forth slightly. It seems that the play is coming from where the disK that hits the pad is riveted to the part that is secured to the bike. Do these typically loosen like this? Is this at all normal? I can't believe I would have to replace the disk after only 6 months of riding. Thanks for any input.
  • matt116
Posted July 04, 2006 - 04:36 PM
it's normal
  • barch88
Posted July 04, 2006 - 06:18 PM
I can shift mine back and forth just a tiny bit too, so I guess it's normal.
  • Matt96xr6
Posted July 04, 2006 - 08:32 PM
it is called a floating rotor for a reason
  • Fastest1
Posted July 05, 2006 - 06:10 AM
It is called a floating disc because it floats from side to side not back and forth, however a little play is expected. It doesnt effect your stopping at all.
  • ben_suhard
Posted July 05, 2006 - 07:16 AM
It's designed to be loose so that it doesn't warp, it's normal. It'll last you at least a couple hundred hours, maybe even five hundred.
  • NorCal
Posted October 17, 2007 - 04:06 PM
How do you know when there is too much play? There is only 100 hours on my bike and I don't want to replace anything unless it is necessary (sorry to bring up an old thread).
  • KAS
Posted October 17, 2007 - 04:21 PM
Its normal. I had an EBC floating rotor and it was pretty sloppy.
  • 0 reviews
  • Hot  33 replies
  • 9 replies
  • Hot  36 replies
