Hi.i have an 86 xr600r. bought it from orig. owner years ago.he had it wired for a brake light, works great. also there is a hot wire that was added into the system, run up under the tank. i'am guessing he was going to use it for blinkers. my ? is should i be able to buy a tail lite converter and use that to hook up turn signals with running lights in the front? i looked at a HOPKINS brand, #48925. also i have single filament lights, running lights. if i hook up the front only with running lights will the converter switch it to blinkers when i flip the switch? i plan on putting in a flasher after the relay, then to the lights, with the wire from the relay marked running going to the front. does this sound close? thanks for any help. tim
advice wiring lights
Started by timothypg, Jul 02 2006 06:02 PM
No replies to this topic
Posted 02 July 2006 - 06:02 PM
