New rear break pedal
5 replies to this topic
  • woodsk
Posted July 02, 2006 - 01:52 PM
Took a pretty good tumble this weekend and need a new rear break pedal. The OEM one is $114 wich is a little stiff for some cast alum. but I cannot find an aftermarket one other than one from sunline which will not be avaliable for some time.
Anyone know of an aftermarket break pedal for YZ/WR?
  • mtrablue
Posted July 02, 2006 - 08:14 PM
your best bet is ebay. get on and do a little homework. i'd bet that brake pedal is on a lot of yamaha wr/yz's.
  • Drunken Monkey
Posted July 03, 2006 - 02:27 AM
you should use a brake snake. It is wire that ties the brake pedal to the frame so it cant be bent out and snapped off. Save you $$$.
  • woodsk
Posted July 03, 2006 - 10:30 AM
I'm with you on the break snake, have one on my 400, but not on my 450. I will now though.
Thanks for the input
  • bluebike1999
Posted July 03, 2006 - 02:19 PM
you probably already have the part number, but you can copy this and get a quote from here.
5TA-27200-00-00 PEDAL, BRAKE
you can try these guys
see how you go.
good luck
  • 642MX
Posted July 03, 2006 - 04:10 PM
Here you go, the brake pedal is less than $77 here. click here
