Just installed my Acerbis Rally Pro Hand Guards
8 replies to this topic
  • MountainMax
Posted July 01, 2006 - 01:21 PM
Thanks guys for recommending these, they are great, aluminum inside them for strength in case I fall, lol. Here are some installed pics.
  • bcs
Posted July 01, 2006 - 07:26 PM
max, what did you mount the mirror to? does it still pivot down from there?
  • MojaveThumper
Posted July 01, 2006 - 07:47 PM
Did you find that you had to trim up the clutch handle? Had too on mine
  • red7
Posted July 01, 2006 - 08:05 PM
Looks good....I love mine!
  • MountainMax
Posted July 02, 2006 - 07:22 AM
I never had to trim my clutch handle as my signal light switch moved the clutch lever in already so it cleared, I did put three spacers on the brake side to clear the lever though. I mounted my mirror over to the left further and screwed it on to the hot start lever, I had a post and better pics on this earlier,
  • minkkinen
Posted July 05, 2006 - 01:41 PM
Looks good... Do you have the front brake hose going under, or on top the inner mounting bracket???
Thanks... Sami
  • MountainMax
Posted July 05, 2006 - 02:51 PM
I cut off the top tab of the brake housing and rolled the hos up and over, seems to work fine.
  • Thumper_Bloke
Posted July 05, 2006 - 03:30 PM
Nice, those are the same ones that came on my 2004. They protect very well.
  • MountainMax
Posted July 05, 2006 - 05:48 PM
right on, on those cold Labrador days, they will help a little to keep my hands a little warmer, as you can see i ride when there is still snow around, short sumers this far north, got to get out when you can
