Not your every day oil thread!!!
4 replies to this topic
  • Assassin
Posted June 30, 2006 - 11:40 PM
I know my oils, but I wanted to know if anyone experimented with different oil weights?
Which would have the best cooling effect? I am sure the lightest weights will make more power, but using "radiator" theory (more flow against hot part, cooler it is), would it also make your bike run the coolest?
I have seen that two2cool stuff, but I don't want to use it because I don't know what it is? Heat is from friction, so it must be a friction modifier, right?
  • Drunken Monkey
Posted July 01, 2006 - 06:05 AM
I have tried different weights, but I couldn't really tell any difference in heat?
I have had great success with PWR oversize radiators and engine ice coolant to keep my bike cool.
Posted July 01, 2006 - 07:23 AM
Most heat is the result of burning fuel. Other than in the clutch, friction isn't a major contributor.
Oil doesn't make a very good coolant because heat doesn't move through it well compared to other fluids. Only the oil that actually touches a hot part absorbs much heat, and only the oil that actually touches the surface of an oil cooler will give much of it up. I doubt that viscosity would contribute much to cooling, and in fact, it could be the reverse of your assumption. Note that oil spray is sometimes used to cool the piston. In this setup, oil is constantly being replaced by new, cooler oil, and the increase in flow that would result from a lower viscosity would probably increase cooling, rather than reduce it.
  • aford541
Posted July 01, 2006 - 07:30 AM
One of the 250F factory supported teams did a test on a dyno with temparature probes in the oil and coolant.
Moutul synthetic oil made the most power and produced the lowest temparatures of the oils they tested.
  • Assassin
Posted July 01, 2006 - 08:39 PM
Thanks grey, thanks aford, thanks monkey!
I actually use the motul 7100 synthetic, I can't afford the 300v!
You guy's might know, does the weight of the oil have any effect on the life of the oil?
Or is that more to do with synthetic - non synthetic?
  • Hot  79 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  36 replies
  • 0 replies
