stripped oil bolt, what to do
1 reply to this topic
  • elcamino76
Posted June 30, 2006 - 10:33 AM
I was working on my older dirt bike, not my yzf, and noticed the banjo bolt was leaking alittle so i decided to tighten it and it turns out to be stripped, and ideas on a fix for it. I was told it was a banjo bolt so i hope that is the correct term. it is the bolt for the oil line with the two copper washers. Thanks.
  • lazybones51
Posted July 18, 2006 - 04:25 AM
yeh banjo bolt is what is called , have you got the bolt out or is it stuck, if it is out jus pop down to your local stealer and they should be able to order you one .
I know this because i done the same thing a couple of weeks ago :thumbsup:
