piston skirt broke...why , kx60 , 1 year on it
10 replies to this topic
  • Trail monkey
Posted June 29, 2006 - 08:23 AM
what would be the cause of a piston breaking at the skirt line, piston only had one season on it, in my boys KX60
Thanks
  • NYMXer
Posted June 29, 2006 - 08:43 AM
You asked a lot from a piston to go a whole year w/o changing and that's why it broke. When my son ran his 60, we did the top end no less than 4 x's a season. :ride:
  • kawirider
Posted June 29, 2006 - 08:44 AM
My friends KDX220 broke the skirts off the piston almost a year ago. They determined that the bottom end bearings got ground up which allowed the piston to vibrate side to side in the cylinder. They had to replace like everything in that motor.
  • KXMike
Posted June 29, 2006 - 09:01 AM
exactly. i have seen this happen in 85's many times. trail monkey, i would replace the bottom end bearing also. i have seen many times where they just replace the top end and when its all put together the bottom end bearing explodes and peices of the bearing get on top of the piston and screws everything up.
  • snowxdadx3
Posted June 29, 2006 - 09:06 AM
The stock one is cheasy/thin. :ride: Compare a Wiseco to the stock one. Much thicker. :ride: Plus, think of the torture that little piece of aluminum goes thru-hot cold, wot, idle, shaking side to side as it goes thru a stroke. Actually amazing they live that long at all. Our kx60 made it 1 and 1/2 seasons, finally gave up when my youngest :ride: decided to prove that water cannot be compressed-over the seat deep!
  • MotoMac
Posted June 29, 2006 - 11:25 AM
Don't know if it is still the same, but when I bought my youngest son his KX-60, the owners manual emphasized that the rings should be replaced every three races and the piston replaced every six races. Even if your son doesn't race it, the piston still takes a beating. Piston, rings, and bearings are cheap insurance for what it's probably going to cost you after the skirt broke off.
Cheers,
Mac
  • danman
Posted June 29, 2006 - 11:28 AM
High Rev = High Pressure = High wear
Basically that is WAY too many "high's" to go a whole year.
  • dorkpunch
Posted June 29, 2006 - 02:17 PM
i've also heard that pistons can "crystalize" if you start the engine and shut it back off without letting the engine warm up. The sudden heat cycling will make the piston brittle. dont know if its true, but hey, you never know.
  • RickyD
Posted June 29, 2006 - 04:26 PM
The skirt catches on the exhaust port du too wobbling around in the cylinder..
  • RCannon
Posted June 29, 2006 - 04:55 PM
The little bikes have a very limited top end life, even at trail speeds.
  • Gadsen
Posted June 29, 2006 - 05:31 PM
If there is any extra bearing clearance, the piston will travel further down in the bore and hit the crank and break the skirts off, especially under load (powerband).
Differences between the F and FX? by motoxpress
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  49 replies
2016 kx250f bogs when upshifting by Eric556
Dirt Bike   Make / Model Specific   Kawasaki   KX250F
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
Low compression J & E piston 2014 CRF450R by stroker
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  28 replies
2015 wr450 engine knock. Video inside. by cdf450
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  58 replies
