Changing a Dirt Bike Tire
Tires & Wheels
No replies to this topic
  • MOmilkman
Posted 29 June 2006 - 05:24 AM
Tires cost a lot of money so why would you want to give your dealer even more to put one on?
Now a lot of people have different methods and ideas on how to do it properly and I am sure they all work fine, but if you follow my instructions you should be changing tires in no time.
Item's you will need to have on hand before you start this project:
A waist high place to work, 2 or 3 tire irons (I prefer Motion Pro's), a new tire, a new tube (optional), baby powder (optional), an air source (compressor), and a rockin' stereo, and patience! (the last is probably the most important!)
Note: Tires are much harder to change if they are cold. If you can lay your new tire in the sun or somewhere hot while taking off your old tire, do it! It will make your life much simpler when it comes time to put the new tire on.
I have posted several pictures during different stages of removing an old tire and installing a new tire. Look for the link in the text, and click on it to take you to that picture.
<hr>
Step 1 - Getting your old tire off
Once you have the wheel off the bike the easiest way to approach this task is to find a surface to work on so you wont have to stoop over and work off the floor, as that can get tiresome. I found an old barrel that was once used for electrical cable and it fits the diameter (18") of the rim of my bike perfectly. It can be smaller but I wouldn't go larger than that because the rim will fall into the barrel once you get the tire off.
Now that the tire is off the bike and you have a good working surface, the first thing you want to do is take off the rim lock nut(s) and the valve stem nut. Remove the core of the valve stem or just release the pressure in the tube (all the way) by pressing on the valve stem core. Now lay the tire on your flat surface and push with your hands trying to break the bead of the tire from the surface of the rim.
BE ABSOLUTELY SURE BEADS ON BOTH SIDES ARE BROKEN DOWN BEFORE PROCEEDING If the tire rubber is a hard compound then it might be hard to break free, but just keep pushing on it with the palms of your hands and it will eventually break free. (Motion Pro makes a tire bead separator specifically for this job. It is not necessary but it does make the job easier) Break the bead loose on both sides of the tire. You can use C-clamps to hold the sidewalls together and MAKE SURE to get the bead(s) down in the drop center portion of the rim opposite the tire irons.
Lay your tire down on your working surface with the sprocket side down, grab your tire irons (I like the Motion Pro tire irons myself) and put the lip of 1 tire iron on the tire. Now, pull the iron back. I like to rest the handle of the iron under the brake rotor to hold it there (it will not hurt your rotor) while I work on the second bite. NOTE: VERY IMPORTANT! -  After you take the first bite on the tire take your palm and push down on the bead all the way around the tire. Then flip it over and do the same thing on the sprocket side. The purpose of this is to keep the bead of the tire to the center most part of the rim and will allow you to stretch the tire over the rim MUCH EASIER! (Additionally, it will make it much easier if you do this after the 2nd and 3rd bites also)
The second bite is the toughest step in getting the tire off.  It is kind of tough to get the tire iron in between the rubber of the tire and the rim because of the pressure the 1st tire iron already putting on the tire. The secret is not taking to big of a bite on the second and 3rd bites. Wiggle the tire iron back and forth until you can slip it under for a second bite on the tire. Pull it back and rest the handle under the brake rotor. Now if you have a 3rd tire iron then you’re in great shape. Just use it like you did #2 tire iron and then rest the handle of #3 tire iron under the rotor. Then go back to the first tire iron and remove it. (this may take some wiggling and patience) and place it in front of #3 and keep rotating them until you have one side of the tire off. (If you only have 2 tire irons then it might make it a little tougher but can easily be done. Just keep rotating the 2 tire irons until one side of the tire is off) Now that one side of the bead of the tire is off, reach inside the tire and grab the rim lock(s) and pull it out. Also grab the tube and pull it out. All you have to do now is get the rest of the tire off the rim. This is the last step in getting the old tire off.
This part is very easy, keep the rim with the rotor side up and put your tire iron past the bead that you just pried off and down to the lower bead. With the lip side of the iron facing the tire pry the lever downward toward the rotor and rest the handle once again under the rotor. The tire will be in a severely misshapen manner at this point but that's fine. Grab your 2nd tire iron and do the same thing and then your 3rd if you have one. Once you get about 5 or 6 bites on the tire just grab the sucker and pull it off. It shouldn't be any problem at this point. NOW IT’S OFF! Congratulations!
Probably the most important step when putting a tire back on is not pinching the new tube. If your old tube does not look extremely chaffed you can probably use it again but using a new tube each time you change a tire is the best preventative method to keep from getting a flat on the trail.
I use Bridgestone Heavy Duty tubes because they are much thicker than a standard tube and therefore wear quite a bit longer. Thicker tube = less wear = less flats. But if you are learning how to change a tire chances are you are going to pinch 1 or 2 tubes with the tire irons before you figure out the best method. But you can greatly reduce your chances of pinching the tube by not pulling the lever all the way forward. Instead, just push the lever enough the tire slips on, and then back off. Please click here for a visual illustration
It is much easier to get cheapo tubes in than it is the heavy duty tubes. Heavy duty tubes run about $18 and cheap Kenda standard tubes run about $7-8. So staring with a cheapo tube might not be a bad idea either. Your call.
Step 2 - Putting that new tire on
First thing you should do before putting your new tire on is check the rim for any sharp edges that might catch the tube as you are installing it. If there are any present then take a file to it and smooth it out. Secondly, look at the sidewall of the new tire. Does it have a arrow on it pointing in a certain direction? If it does then be sure and mount the tire with the arrow pointing in the direction that the tire will be rotating. I run Dunlop tires myself and I have never seen an a arrow on one but I know some tires do so watch out for that. Paddle tires are one specific kind of tire that has to be mounted in the correct direction. You want the sand to be "scooped" by the tire not hit by the backside of the paddle.
The first thing you want to do is lay the tire over the top of the rim. (still working from the rotor side) Now, you can push it on about halfway before you will have to start levering it on. Grab your tire irons and this time use the lip of the tire iron on the edge of the rim and not the tire. Pry outwardly (away from the the wheel). Hold the lever in place and grab your other tire iron and get another bite. (not too big of a bite - about 2-3 inches apart) Keep rotating tire irons until the first side is on. Next thing you want to do is put in the rim lock(s). Thread the nut on to the rim lock after you run it through the rim. Do not thread it down all the way just 2 or 3 turns after it starts to thread.
Fill the tube with just enough air that the tube is not collapsed on itself. You want the tube to have enough density that when you slide a tire iron in it wont pinch it when you are putting on the final bead. Now take your baby powder (or talcum powder) and coat the outside of the tube. This will help the tube slide around inside the tire and the tube will not chaff so much. Now comes probably the toughest part of changing a tire. (not what you wanted to hear is it?) Take the tube and place it inside the tire with the valve stem parallel with the hole in the rim. The tube should be in the tire but also over the rim as much as possible. Now you want to get the valve stem though the hole from the inside right? Seems impossible but with some determination and a little luck you can squeeze your hands in there and guide it though. I learned a little trick years ago on how to make this much simpler than just guessing where the valve stem pokes through. Just take a very small screwdriver and from the inside of the rim (spoke side) run it though the valve stem hole
Then put the valve stem on the end of the screwdriver and guide it through. Wa-La! No problem eh?
Now all you have to do is put the last side of the tire on and your done. Starting where the rim lock is push the tire down over the edge of the rim using your hands. Just push as hard as you can and you will see the tire sliding over the edge of the rim. Do this as far as you can moving from the rim lock outwards. Once you have pushed it on as far as you can, FLIP THE WHOLE WHEEL OVER AND MAKE SURE TO PUSH THE BEAD DOWN IN THE DROP CENTER PORTION OF THE RIM. This is very important to do. Not only will it make your tire change so much easier, if you stretch the tire bead too much you can ruin the tire. I know, because I did just that when I first started changing tires.
Now flip it back over (rotor side up) and spray the bead of the tire down with a slippery substance. Soap and water works great. You want to have this on for 2 reasons. One, It helps the tire slide over the rim easier and two it helps you keep from pinching your tube. Now grab a tire iron and place the lip of the lever on the rim carefully noting that you DO NOT have the tube pinched in between the rim and the tire iron. Push the tire iron back and hold it in place. Grab the other tire iron (hopefully it is close to you) and place it on the opposite side and lever down another section of the tire. Keep holding the first lever in place and pull out the second lever and keep working it all the way around. After about 3 bites, flip the tire over (to sprocket side) and push the bead down all the way around. Do this on the rotor side again too. Once again, remember, this is the most important thing to keep doing when changing tires. Keep levering the final side on until you get the last of the bead back on the rim. Now you have changed a tire!!!!
All you have to do now is put the nut on the valve stem and put some air in the tire. Wet down both sides of the tire bead with soap and water and put about 60 lbs of air in the tube. This will seat your tire. If it doesn't then let the air back out, bounce the tire on the ground in the area it is not seating and fill with air again.
Then tighten your rim lock, valve stem nut and set to the correct air pressure and put that sucker back on and go riding!
This post has been promoted to a wiki
