bog
7 replies to this topic
  • 116CJ
Posted June 27, 2006 - 05:31 PM
i have read the jetting thread and i did a search. I have an 06 450 and when its idling and i wack the throttle it bogs or hesitates then hits. Is this common? it seems to get better as i move out the air screw but should it be out 3 1/4-1/2 turns out? I have tried the 170 main, 168 main and 165 and i have tried the 45 pilot with the 168 and 170. now i dont notice it much while ridding but if your sitting there idling and just wack it, it does it which leads me to think something needs an adjustment. or is this what the boysen quick shot fixes. I am new to 4 strokes so any help is apreciated.
  • WFOracer
Posted June 27, 2006 - 05:48 PM
I have the 06 as well and swapped out the stock jetting. I run about 800' elevation - 70-90 degrees
I went with a 48 pilot and run either a 170 or 165 main, depending on temp. My fuel screw is usually around 2 turns out, give or take a 1/4 turn.
Posted June 27, 2006 - 05:58 PM
First, the bike needs a bigger pilot. I run a 45. Go with a 45-48.
Second, what it does in neutral is meaningless. the timing and advance curve are different in neutral than once in gear.
Third, what everyone needs to understand about 4-strokes is that even with an accelerator pump and perfect jetting, they can be shut down by snapping the throttle open hard enough at the spec'd idle speed in most cases. Attempting to get rid of that requires going beyond the accel pump and jetting levels that are needed for good performance. You should, instead, learn to roll the throttle open rather than snap it.
This technique involves opening the throttle more slowly at first, and progressively faster as the engine responds. Once you learn it, anyone listening to the bike will think you're simply flipping the throttle. I can make any of mine sound as if they exploded off idle right to 7000 without giving it a thought, and the important thing to realize is that the "bog" never shows up when you're actually riding.
  • 116CJ
Posted June 27, 2006 - 06:04 PM
cool thanks guys, the warmer the tempertature the leaner the jet? like say 90 run the 165 and 70 run a 170? im going try out the 48 pilot. has anyone had to change the needle possition?
Posted June 27, 2006 - 06:39 PM
Not me.
  • yamahacrazy_310
Posted June 27, 2006 - 07:36 PM
I run the 170 and it runs perfect in wormer temperatures.
  • SureBlue
Posted June 27, 2006 - 10:50 PM
Raise the needle one clip too, it took away the slight bog and surging on mine. And think of it: if you need a larger pilot and a larger main, why would you not need to give more fuel at midrange = raise the needle?
  • mankind810
Posted June 28, 2006 - 01:25 AM
Grayracer is on the money about bog.
This man is very good with his advice and his posts should always be consisdered. :excuseme:
  • 10 replies
  • Hot  28 replies
  • Hot  30 replies
  • On January 15, 2017
