1/8 sputtering? i am crying for help
44 replies to this topic
  • duke2au
Posted August 27, 2006 - 09:02 PM
#41
I know this is an old thread, but i felt like a had to commend "lavoie du christ" for his efforts in finding this problem. It read like you went through some real pain. I am going through the same problem and was amazed on how much our stories compare.
I too have a 03 wr450 with the same problem. After rejetting ,dynoing and asking "backyard experts", I can now get back to the bike after 2 weeks of it being in the "too hard basket" and fix the 1/8 throttle surge. Again thanks for your persistance.
I will report back :thumbsup: :ride: :applause:
  • Poway1464
Posted September 23, 2006 - 10:19 PM
#42
I have this same problem. Did it work for you?
Larry
  • lavoie du christ
Posted September 25, 2006 - 03:59 PM
#43
Simple.. disconnect your TPS and check if your bike runs better.
If not, i guess you have to play with your jetting and make sure you dont have an air leak somewhere.
  • wr450_21
Posted September 27, 2006 - 01:53 PM
#44
i had the same problem on my 03 450 and it turned out to be my hot start o ring in the carb i replaced the hole thing and ran grate after that
  • Poway1464
Posted September 28, 2006 - 09:30 PM
#45
Well I have checked the TPS and it tests fine. The problem is still there - with or without the TPS connected. I guess I will check the Hot Start O-Ring, next. This is absolutely the worst POS I have ever owned. Simple jetting to who knows what. I have spent over a month, bought a JD kit and $260 and 2 weeks at the dealer. Still not resolved. I think it is getting worse not better.
I feel like going back to red.... :thumbsup:
