Re-Starting Problems
4 replies to this topic
  • mxrayser
Posted June 26, 2006 - 03:05 PM
Im having issues with starting my 04 450!! When restarting the bike if it doesnt start on the first kick im screwed, have to wait a couple of minutes and try again, any cures to this will be appreciated and rewarded with a six pack of the TTers choice ThanX :busted: :bonk: :excuseme:
  • mxrayser
Posted June 26, 2006 - 03:13 PM
I went from 165 main to 170 and 42 pilot to 48 then 45 seems to be better, but ive thought that before
  • stock510
Posted June 26, 2006 - 03:19 PM
It may well be the PILOT JET.
If your having trouble starting your bike it can often be fixed by installing a larger pilot jet, therefore giving the system more fuel at start up (It should start easy with a larger Pilot jet installed :excuseme: )
How is the bike running once it does start? Popping badly on closed throttle?
Posted June 26, 2006 - 04:50 PM
When you say "restart", I assume you either stalled or crashed. In those cases, the bike is much more likely to either be flooded, or easily get flooded because the carb has overfilled itself. Try this:
Hold the hot start and kick the bike with the throttle held SLIGHTLY off idle (between an eighth and less than a quarter). If it doesn't go in 3, back off on the throttle some and try it without the hot start.
  • mxrayser
Posted June 26, 2006 - 08:09 PM
ThaanX Gray, I'll try that
  • Hot  28 replies
  • Hot  47 replies
  • Hot  36 replies
