03 wr 450 pipe
5 replies to this topic
  • bigblockchevelle
Posted June 26, 2006 - 07:47 AM
Hey guys, my 03 wr is Canadian and does not have any way of changing or removing the baffle in the pipe as it has the tip welded in. Would i benefit from a stock yz 450 pipe and if so, do i have to rejet the bike for it? thanks
  • Yamaster
Posted June 26, 2006 - 08:26 AM
You will probably benefit from the yz pipe, you will also probably have to up the main. Get the pipe, do a plug check and jet from there. Black plug= too rich, white plug= too lean, tan plug= perfection. (Although I like to run my bikes on the darker side of tan so I'm not lean if I ride in lower elevations or temperatures.)
  • AUS_WR450
Posted June 26, 2006 - 10:27 PM
Maybe you could consider looking at this very cheap modification I did, if you have the same pipe as the Aussie version.
To answer your question, yes I had to rejet to achieve the best performance from the bike.
WR450 muffler mod
  • Looks450
Posted June 27, 2006 - 12:24 AM
I have gone a YZ pipe and i didn't have to rejet it. The yz pipe is a cheap and easy option
  • bluebike1999
Posted June 27, 2006 - 01:49 AM
WR450 muffler mod
i did that mod too,
didnt rejet though, goes just fine, starts easier,sounds good
http://img.photobuck...99/DSC00061.jpg
http://img.photobuck...99/DSC00062.jpg
$30 all up.
  • bigblockchevelle
Posted June 27, 2006 - 04:16 AM
thanks for the advice guys. this thing just feels like it needs to be opened up a little.
