Leak at the base of the cylinder
4 replies to this topic
  • darthmullet67
Posted June 26, 2006 - 05:24 AM
I was looking at my bike the other day and noticed that on the right side of the engine there seemed to be some oil or coolant laying next to the cylinder on top of the water pump. Has anyone else had this problem and what was the cause? My bike only has about 10 miles on it because I have been in the process of dual sporting it. It is still under warranty and I will be taking it into the shop but I wanted to ask the experts first!
Thanks
  • Yamaster
Posted June 26, 2006 - 08:22 AM
Its probably a blown head gasket. If you only have 10 miles on it, I dont understand how it could have blown, unless it was ripped or something when you got it.
  • LimyWPom
Posted June 26, 2006 - 09:28 AM
just a possibility,but have you recently done an oil change? because I have noticed oil on that side when you undo the oil gallery bolt(top of cylinder) until oil seeps out, my 05 was leaking a bit
until I replaced the copper washer
  • ONLY4STROKES
Posted June 26, 2006 - 12:02 PM
Sounds like the fluid is coming out of the weep hole. Replace your head gasket. If the stuff is coming out by your water pump...then it would be a blown water pump seal.
Doug
  • Indy_WR450
Posted June 26, 2006 - 12:34 PM
Most likely it is the bolt that holds the oil line that feeds to the oil filter from the head. It is located just above the oil filter next to the water pump and oil will flow along the base of the jug and it may fool you. :excuseme:
