Which Dual Sport Kit should I buy?
16 replies to this topic
  • philipstjohn
Posted June 25, 2006 - 05:54 PM
Please give me your feedback and share your experiences on the dual sport kits which works the best. Baja Designs seems to be the most popular, Electrosport seems to make a good set up, and then there is the Trick Dual Sport kit. Not sure which way to go as I have had no experience with any dual sport kits. Please give me the heads up. Thanks :excuseme:
  • Jon-D
Posted June 25, 2006 - 06:35 PM
I have the Trick kit and have been pleased with it so far. it is fairly simple to install and remove when you want to go off road. Dale is also pretty good when it comes to customer service.
  • willnevergrowup
Posted June 26, 2006 - 03:49 AM
I have just recently was asking the question you did!
After alot of research I went with the Baja Design Quick Release and would do it again just because of the ease of putting on and the way it looks. Haven't had it on long enought to say it holds up, but so far so good!
Have a great day!
  • philipstjohn
Posted June 26, 2006 - 07:38 AM
The BD kit seems easy, how does it work at night? What watt bulb are you running in the headlight?
  • jamestoo
Posted June 26, 2006 - 01:21 PM
happy with my baja designs kit
  • Miguel159
Posted June 26, 2006 - 05:36 PM
Has anyone tried the quick release Baja Designs kit? It's the one with the flush mount signals mounted on a replacement rear fender. Do you need a sub frame extension (ala SRC) with that kit?
  • willnevergrowup
Posted June 26, 2006 - 06:24 PM
The Baja Design mounts just like the existing fender with no support brackets. I do have the flush mount lights and happy with the way it looks.
As far as the watts of the light I am not positive and can't seem to find it anywhere. I have definitely seen brighter but not bad for night driving!
Elmer out
  • Infidel
Posted June 26, 2006 - 07:58 PM
I put on the SRC subframe although I don't think it's needed. The SRC rack does not fit with the flush mount signals.....I'm still thinking and figuring on a solution......
Anbody got an opinion.....?
  • Mescalero
Posted June 26, 2006 - 08:50 PM
I use that kit and no sub frame extension is needed. The flush mount turn signals are nice versus the norm because my big ol boots dont clip them when swinging a leg over the saddle....... they are also out of the way when you dump it. The whole thing including the headlight assembly is off and swapped out with the stock plastic within 15 minutes or less.
  • xr650r_Maine
Posted June 26, 2006 - 09:36 PM
You can order the flush mounts with the B/D kit on stock fender, no extra charge. I ordered the EZ mount kit, frt brake light switch, 250watt stator w/90/100 watt H-4 bulbs,key switch kit."note" you have to send them your stock stator for a rewind $120.00. I`m ready to "Get-r-done"
  • MSHAM
Posted June 27, 2006 - 07:33 AM
I have a BajaDesigns DS kit on my WR. I sent back the first main switch because the High/Low buttonn quit working. My second main switch is doing the same Thing. The License plat mount broke on me as well. I don't have very many hours on it yet either! good luck!!!
  • InternalCombustion
Posted June 27, 2006 - 04:12 PM
Two years ago when I was building my R-based supermoto, I opted for the E-Line street kit. My number one reason was the slick flush-mount turn signals front and rear.
Big mistake. The E-Line kit uses a "black box" to do all the traditional functions, like voltage regulator, turn signal, high-low switch, battery, etc. Up-side of this is a very small, compact design. Down-side is no chance to repair it if something goes on the fritz, or to switch blinker module to allow LED turnsignal bulbs, etc. Plus their headlamp bulb used some weird lamp-base and after WEEKS of research I was only able to find one upgrade option on the whole planet.
Plus, a couple of months ago my brake light function stopped working. I could see the signal was coming through but it was super-weak and any bulb would pull it down to zero!!?? E-Line has dropped this kit, best I can figure, because I cannot find it anywhere on the web now.
Last month I got tired of all this and ordered a full set of "real" wiring components: regulator, handle-bar switch cluster, fuse panel, real BATTERY!!, etc, from ProCycle.us. Gonna use the E-Line wiring harness and just replace the blackbox with real components.
I think that's the route BD takes with their kit as well, so BD would probably be a safe bet. You do not read too many complaints about BD's stuff.
Good luck!
Ride Safe.
  • del435
Posted June 30, 2006 - 09:38 PM
I like Electreks. turn signals stick out but i do alot of riding in town. I havent broken light off yet. I take that back, riped the tailight off up at the dunes. I now run brake and tail light inside the stock lens.
  • BBD
Posted August 08, 2006 - 09:57 AM
I bought a Trick Dual Sport kit a couple of years ago for my BRP and am thoroughly pleased. www.trickdualsport.com
Dale is a great guy and his solution is well engineered.
  • BluezookS
Posted August 15, 2006 - 03:17 PM
Hey, InternalCombustion
Where did you put the battery?
Small 12 volt 1.3 amp hour sealed battery
Dimensions: 1.7" X 2.0" X 3.8" Weighs only 20 ounce $29.95
http://procycle.us/main/dskit.htm
battery towards the bottom
Posted August 15, 2006 - 03:38 PM
Just above the headlight, behind the fly-screen / number plate. I'll take some pics and post them to My Garage in the next day or two. I fabbed a u-shaped support frame out of 3/4" angle aluminum. This was bolted to the fly-screen then the battery, and a few other electrical components were mounted to this framework. Pics will explain it better, but I gotta warn you, I am real anal when it comes to fabbing and wiring so I was shooting for a sano job.
I will update this thread when I post the pics.
  • beerjonny
Posted March 08, 2007 - 10:45 AM
:applause: No pics :lol:
