04 450 Carb Dial
9 replies to this topic
  • mxrayser
Posted June 23, 2006 - 11:55 PM
There a dial on the bottom of the carb numbered 1, 2 , 3, 4, anybody know what exactly its for? :excuseme: ThanX
  • flintlock28
Posted June 24, 2006 - 07:29 AM
It is an aftermarket fuel screw.........
The stock carb comes with a recessed fuel screw, that is a pain in the azz to adjust, since it sits so far recessed. Some aftermarket companies (i.e. Zip-Ty) and other's offer an aftermarket screw that replaces the stock recessed. You remove the stock screw, and put in the new knurled knob. I'm guessing the color is an anodized red color right?? If so, than the previous owner must have installed a Zip-Ty
I have one on my bike, and it is a great product for adjusting the fuel mixture from idle to about mid-throttle. To adjust it to give you the best throttle response:
Make sure the bike is fully warmed up...Ride it at least a few minutes.
Let the bike idle in neutral, and then turn in the idle knob to increase the idle above normal. Turn the Fuel screw slowly in until you hear the idle begin to drop, and the bike will nearly stall. Begin to slowly turn the knob out until the bike reaches maximum R.P.M. Stop when it reaches maximum (highest) R.P.M. At this point you will be at approximately the best setting for the fuel screw. The 1,2,3,4, numbers are marked on the fuel screw, so that you can tell how many 1/4 turns you have moved the screw in or out. If my bike's fuel screw is not set correctly, than the bike will feel sluggish (i.e. running rich), a little adjustment of the fuel screw, and it's pulling the front wheel skyward again...Hope this helps...you can also do a search of Zip-Ty fuel screw.
Don
Oh, one last thing; When you turn the fuel screw in....DON'T bottom the fuel screw all the way in TOO hard. If you turn it in all the way TOO hard, you could crush the tiny little tip on the end. In most cases, I think you need the fuel screw to be turned out from fully in, between 3/4 of a turn to 2 full turns out for normal operation. If you have to be turned out less than 3/4 of a turn, or more than two full turns out, than I think the leak jet has to be changed.
  • Ga426owner
Posted June 24, 2006 - 07:30 AM
Yes and be glad the previous owner bought this for you.................
it is a adjustable fuel screw....... :excuseme:
  • mxrayser
Posted June 24, 2006 - 11:00 AM
Don
Don, Thanks for the detailed info, appreciate it George AKA mxrayser
  • mxrayser
Posted June 24, 2006 - 11:01 AM
ThanX
  • Fastest1
Posted June 24, 2006 - 09:29 PM
Usually that indicates the need for a pilot jet change.
  • mxrayser
Posted June 25, 2006 - 01:16 AM
Got it, ThanX
  • ben_suhard
Posted June 25, 2006 - 06:26 AM
The full story (and no typing for me) http://www.motocross...032722A4D5D52E3
  • ben_suhard
Posted June 25, 2006 - 06:34 AM
Yep, pilot jet. The leak jet is for the carby pump.
  • flintlock28
Posted June 25, 2006 - 09:53 AM
Yep, You guys are right, I had a Brain Fart...
It's the pilot jet, not the leak jet.
Don
  • Hot  113 replies
  • 9 replies
Motocross
  • Hot  491 replies
