Trailtech Vapor is out! yay!
18 replies to this topic
  • nitronaf
Posted June 21, 2006 - 11:38 PM
Well finally the "may" shipping date has come and the vapor is out
http://www.trailtech.net/vapor.htm
http://www.trailtech...mputer_kits.htm
Seems pretty easy to install http://www.trailtech...nstructions.pdf
i dunno how accurate wrapping wires around things is tho hmm
they even brought out protectors straight away yay http://www.trailtech..._protectors.htm
me go order one and tell u guys how she goes
anyone wanna buy my old odo's? (06 stock and trailtech endurance) :excuseme:
  • YamahaWR450FMike
Posted June 22, 2006 - 02:04 AM
oh boy I gotta have one of those. NICE! How much though?
  • muddza
Posted June 22, 2006 - 02:34 AM
Yeah NICE!!, I gotta get me one of them, pretty easy on the coin too, just think Yamaha offer an hour meter alone for around half the price.
  • Matty05
Posted June 22, 2006 - 02:41 AM
$99.95 :excuseme:
  • OneToGo
Posted June 22, 2006 - 02:46 AM
Gee that is nice, great tacho feature!
Full report (unbiased?) from first buyer please!
  • JJHayesIII
Posted June 22, 2006 - 12:36 PM
where can I get one!?
  • Frank_z28
Posted June 22, 2006 - 01:50 PM
HUUUM i like that. i hope they have good durability
  • rushfan
Posted June 22, 2006 - 03:03 PM
I've been wanting one for my '05. I think this will be the one. :excuseme:
  • nitronaf
Posted June 22, 2006 - 03:05 PM
shall do!
waiting for them to ship it out
T__T
  • ETP
Posted June 22, 2006 - 04:12 PM
Wonder if we can use our old style speed pickup sensor with the Vapor?
Looks like the mount has connections for the other sensors, but hopefully we can just splice it in to the new harness. :excuseme:
  • hideto666
Posted June 22, 2006 - 07:50 PM
sorry , might be a :excuseme: dumb question.
will it be easily fit on my dirt wheels and sm wheels ?
meaning will it be a real hassle if i were to switch back and forth between the 2 wheels . :bonk:
  • 06WR450FSM
Posted June 22, 2006 - 09:38 PM
meaning will it be a real hassle if i were to switch back and forth between the 2 wheels . :busted:
I am doing exactly that, but chose to stick with a stock disk for the SM wheels for easier swapping. I'll bet you can figure out a changable setup if you are running a 320mm SM disk.
My Vapor is due to arrive today (Friday) :bonk:
  • Just_a_trail_rider
Posted June 22, 2006 - 10:06 PM
I wonder what it does that the old Endurance doesn't do? Or is it just an updated model?
It sure looks sexy though...
  • minion
Posted June 22, 2006 - 10:44 PM
The only downfall I see is that it doesn't have average speed. I enjoy that statistic when I'm racing harescrambles on my Endurance TrailTech.
  • hideto666
Posted June 23, 2006 - 12:32 AM
My Vapor is due to arrive today (Friday) :excuseme:
i will using the 320mm disc for my sm wheels , and stock disc for my dirt.
so its a trouble to switch back and forth ?
or just stimple adjustment to the trailtech computor.
thanks guys
  • Matty05
Posted June 23, 2006 - 05:10 AM
thanks guys
get another magnetic pick up bolt and you will be fine.
You will need one for each front wheel.
  • simon@vic
Posted June 23, 2006 - 06:33 AM
Sweet!!! thx for the up date!!!!
  • 06WR450FSM
Posted June 23, 2006 - 10:25 AM
thanks guys
Two things:
1) You will be moving the caliper farther away from the disk mounting bolts for the 320mm SM rotor, so your sensor will have to be repositioned. Maybe the sensor could be mounted to the lower leg protector instead of to the caliper so that its position relative to the magnetic rotor bolt remains constant.
2) You have to reset the Vapor when you change wheel size; a minor hassle since you will have to re-enter all the settings. The odo and hour meter never rest to zero, but everything else gets lost. That's what is nice about the '06 stock digital speedo, nothing is lost when resetting wheel size.
AND FOR YOUR SAFETY: A 120mm wide SM tire may interfere with the lower fork protectors and the upper fork tube bottoms as the fork compresses, potentially causing the tire to lock and sending you over the bars. Trim the inner portion of the protectors and then either remove the plastic bands at the bottom of the upper fork legs or trim the tire tread edges because the stock 120mm tire width is the same the opening at the bottom of the upper fork legs.
  • 06WR450FSM
Yup :excuseme:
