Help, can't get the crud out of my carb
6 replies to this topic
  • 150 Fuelie
Posted June 21, 2006 - 06:57 PM
I picked up a mint 04 WR450 that sat for almost 2 years. I had to flush the tank, petcock and carb. Problem is that I can't get all the crud out of the fuel tube that is inserted in the carb that the fuel line attachs to. I have had to pull the carb apart 3 times because crap keeps getting into the seat and causes the gas to overflow. What can I push thru the tube to clean it out that is flexable enough yet strong enough to get out the crud?????
  • farkawi
Posted June 21, 2006 - 07:46 PM
Ultrasound or ultrasonic??? parts cleaners are all the rage for carb cleaning with the vintage crowd. Harbor Freight sells one or you can pop for a more expensive unit from an industrial tool supplier.
  • Beejay
Posted June 22, 2006 - 01:43 AM
If all else fails try a little diluted phosphoric acid
  • GCannon
Posted June 22, 2006 - 07:46 AM
Soak it in hot water if you boil it you may damage the o rings that hold the fitting into the carb body if you heat it up the goo may soften and be easier to push through. when I was a kid my dad and I would do the final clean up on a carb by running it through the dishwasher when mom was not looking man did they come out clean.
  • tarry
Posted June 22, 2006 - 12:20 PM
Try the good ole boy method, carb. cleaner and some strong wire(such as bailing wire) with some cloth strips wrapped around the end! Worked for me in the past. :excuseme:
  • walshy
Posted June 23, 2006 - 04:57 PM
Does your bike go quick enough to outrun LIONS Beejay? I dont like LIONS! :excuseme:
  • ncampion
Posted June 23, 2006 - 05:47 PM
Bead blast it.
