Rejetting for a bike that used to run race fuel
6 replies to this topic
  • scubaru
Posted June 21, 2006 - 05:32 PM
hi all, first of all thanks to those members who helped me narrow my problem down to a jetting issue. Had a mishap while testing the bike the other day and am now stuck in bed with a broken collar bone and bruised/torn rib cartilages : :excuseme: : . My issue with the bike is you can't rev the bike at any position of the throttle in neutral at a constant speed without it popping and there is a fair bit of decel popping when engine braking. Other than that it starts great and pulls extremely hard Thu the gears without any hesitation at all. Did a search on jet sizes but was starting to get confused with some of the opinions so will ask for some advice with the bikes specific details.First of all the bike is an x supermotard bike so it was probably jetted for race fuel and now I am/will be using 98 Ron unleaded. It has a GYTR titanium exhaust, head and cam mods and was dynoed by previous owner at 58 hp at wheels. Whilst I had the carby apart for cleaning I checked the jetting sizes - Starter jet -72
Pilot jet- 42
Main jet-180
Needle- 3rd slot from top
When changing the spark plug it looked to be running lean and the altitude the bike is being ridden at is approximately 300m/400m (900ft/1200ft) .I have tried adjusting the air/fuel screw out to about 4 turns out with only very minor success. Any ideas on jetting sizes would be appreciated or should I just ignore the popping altogether as it pulls extremely hard as it is. cheers and thanks
  • flintlock28
Posted June 21, 2006 - 06:53 PM
A "little" popping is fine, a relatively constant popping when decelerating, is not..and shows a lean condition. I wish I could help you further, but with the bike being set-up for SuperMotard, I would be guessing as far as jetting goes.
I would definately post this in the "Jetting" section, and ask for TT member "burned" to help you.
  • scubaru
Posted June 21, 2006 - 07:38 PM
Thanks flintlock28, I will copy and paste it in the Jetting forum. Was just there reading some old posts actually. Seems the pilot jet may be a tad small, but will post it there and hopefully burned might see it and respond. Thanks
  • Ga426owner
Posted June 22, 2006 - 05:16 AM
You need to jet the bike back to the stock settings - see you manual
then tweek as needed - :excuseme:
  • Fastest1
Posted June 22, 2006 - 07:21 AM
I would have guessed the main to be around a 170 for sea level and 168 up to about 3000'. Race gas will definitely need a bigger main due to being oxygenated. Otherwise the starter and pilot sound about right as does the needle setting.
  • Sapling Thrasher
Posted June 23, 2006 - 01:18 PM
I was always told to lean your motor for race fuel. ohhh so many opinions!!! I run much leaner jets on my snowmobile than I would if I ran pump gas but that is a 15:1 two stroke running full 114 race fuel.
  • scubaru
Posted June 23, 2006 - 04:10 PM
thanks for the advice, love this forum. Forgot to mention that the carby has been machined a couple of mm bigger. Burned seems to think that the main jet seems about right so I will just play with the pilot (a 45 or 48) and try lifting the needle up 1 notch. cheers
