is this a vent line?
12 replies to this topic
  • getdrunk
Posted June 20, 2006 - 02:19 PM
theirs 2 hoses on top of the z426 motor. ones the oil line and whats the other one? just a vent?
if its a vent does it blow hot air out? cause i was thinking of putting it in the intake hose cause i have a spot i could fit it. but if it blows hot air then im not gona do that.
  • barch88
Posted June 20, 2006 - 04:56 PM
One is the oil breather hose, the other is the spark plug?
Posted June 20, 2006 - 05:54 PM
You blew that. We were trying to ignore him.
The big one's the breather, the little one is the pressure balance vent for the oil tank.
What's your BAL today, gd?
  • mtscott
Posted June 20, 2006 - 05:56 PM
That is the way it is on mine, one the oil blowoff and other sparkplug.
I have had oil come out of that blowoff hose when the bike was new and I did not lay it over eather. I have not seen it since then though. Hope that is normal.
Posted June 20, 2006 - 06:03 PM
Yours is an '06. The pressure balance line was moved off of the cam cover. '05 and earlier had two HOSES coming from the cam box.
  • barch88
Just was some overfill from whoever preped your bike.
  • mtscott
Posted June 20, 2006 - 07:03 PM
Yeah, mine is an 06
  • getdrunk
Posted June 21, 2006 - 03:27 PM
so i shouldnt hook that line up to my intake?
  • Ga426owner
Posted June 22, 2006 - 05:28 AM
GD, some will route the breather tube to the airbox if this is what you are trying to convey?
I would only do it if you ride in deep water alot(water can be sucked into the motor) or have a problem in sand dunes sucking sand up your pipe....into your motor.
Do not use it for a beer funnel.......not good :excuseme:
  • getdrunk
Posted June 22, 2006 - 03:27 PM
well when i had the 400ex motor in the frame the motor had a crank case breather tube that went from the motor to the air intake boot. im still using that air boot for the yz motor thats in the frame. i need to hook that tube from the motor up to the intake boot to fill in the hole or somthing. if i dont then ill suck dirt.
so is it safe or is oil gona come out?
  • donutman126
Posted June 22, 2006 - 04:19 PM
The oil is going to mist out.
  • One Louder
Posted June 23, 2006 - 11:30 PM
just plug the hole on the boot and run the line into the airbox :excuseme:
  • getdrunk
Posted June 27, 2006 - 03:45 PM
i run no air box. how should i plug up the hole? :bonk:
