What Oil to use???
7 replies to this topic
  • yzinger04
Posted June 18, 2006 - 07:49 PM
I have just bought a 06 WR450 and have completed the break-in phase and have changed my oil using Castrol Syntec (full synthetic). The "donut" on the back of the bottle has an API rating of SM/CF, but my service manual calls for SG. I did research on the API rating and found that SG is for vehicles '93 or older. I am wondering why Yamaha would call for a specific API value. What do you think I should use? Thanks :excuseme:
  • Solo
Posted June 18, 2006 - 08:00 PM
I can't remember the details but some automotive oils have friction modifiers in them that can affect your clutch in a bad way. (bad way = causes it to slip) That is indicated by the API seal on the bottle. I don't remember what is what because I don't use or shop for automotive oils for use in my bikes.
*I* use Amsoil which is a full synthetic that is intended for use in motorcycles and wont adversely affect your "wet" clutch.
Someone should chime in soon with the details I'm lacking.
  • truly_5150
Posted June 18, 2006 - 08:31 PM
I switched to bel-ray's semi synthetic 4-stroke thumper oil.
i have noticed the difference in the life of my oil between
changes.
  • JSanfilippo
Posted June 19, 2006 - 12:15 AM
Anything labeled "energy conserving" or EC in the API sunburst label on the back of the oil bottle is bad for a wet clutch. If you want good protection on the cheap, HDEOs (Rotella, Delo, Delvac etc) are the way to go. I think I may have opened a can of worms...
  • Chickenhauler
Posted June 19, 2006 - 12:50 AM
I second that motion-and let the worms fly. :excuseme:
  • Matty05
Posted June 19, 2006 - 02:50 AM
Can someone please make a sticky with a list of automotive oils that are good to use? Please?
  • Looks450
Posted June 19, 2006 - 03:08 AM
Bring on the worms i say. Any fully scinthetic is ok. the quality of the oil comes from how long the oil maintains its viscosity. If it is runnier than water when you take it out, i'd look at another brand or increase the frequency of your changes.
  • ArizonaThumper
Posted June 19, 2006 - 05:27 AM
Why make this so complicated, there are so many brands out there specificaly made for motorcycles, just use one and change it often.
I have been using the cheap honda brand for years never had a problem.
You are waisting money on full syn. or the red line, blue line, amsole, or the other expensive brands.
